Old 09-06-2010, 10:03 PM   #1
tbrown5079
LS1 exhaust manifolds
I have a 4.8 LS engine from a 2007 GMC pickup in my 56 cameo. I need a set of exhaust manifols from a Camaro or firebird to give me clearance at the frame rails. I just found a set from a 2000 Camaro. Does anyone know if they will fit?
tbrown5079 is offline   Reply With Quote
Old 09-08-2010, 07:30 AM   #2
63 & 64 Bowties
and a few others
Re: LS1 exhaust manifolds
Since you weren't getting any replies, I moved this for ya to our new LSX forum.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 09-08-2010, 07:38 AM   #3
Juiced06GTO
The stock manifolds from my 5.3 motor fit in my 87. I know its not a 56, but they hug the block fairly close and exit towards the rear which may help you?
Juiced06GTO is offline   Reply With Quote
Old 09-08-2010, 11:15 AM   #4
RocketKing
RocketKing's Avatar
I am also looking for the same info on my LQ4 swap into a '67. I have read that the stock passenger manifold will not clear the frame on my year model. But that around a '98 f-body manifold will clear. I believe that is the same year as 2000. I have also read that the new Trailblazer SS wil fit and may even help with hp.
This is just info that I have been able to piece together, maybe someone who has actually tried these things will post up.
Rex
RocketKing is offline   Reply With Quote
Old 09-08-2010, 11:38 AM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I tried the F-body manifolds and they were the opposite of the stock manifolds. One fits the other doesnt without major frame surgery. I used Sanderson CSLS1 shortie headers, they were the most cost effective and they fit without any frame mods, however there are some LT headers that also work well, Doug THorley I think. I have also heard the TB-SS manifolds work also, but I have no experience with them tho.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-08-2010, 03:55 PM   #6
LEEVON
Moderator
LEEVON's Avatar
You can also scratch GTO manifolds off the list, they stick out too far from the block. I just bought a set of Hooker LS1 block huggers, ceramic coated off Ebay straight from Holley for $200...they would fit almost anything, so tight to the block.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-08-2010, 04:27 PM   #7
Thealien
Thealien's Avatar
I am using the trailblazer SS manifolds and have plenty of clearance. They look like they were made to fit my truck. A little harder to find than the camaro/firebird manifolds but worth it IMHO. I do have a set of 2000 F body manifolds that I didn't use because I found the trailblazer SS ones.
Old 09-08-2010, 07:25 PM   #8
RocketKing
RocketKing's Avatar
Which system did you use to mount the motor? I have read that sometimes it can make a difference on how well the exhaust manifolds fit.
Rex
Old 09-08-2010, 08:16 PM   #9
Thealien
Thealien's Avatar
None of the above. My Jimmy is 4WD so everything is different. But where the engine sits between the frame (same space 2 or 4WD) there is plenty of room with the Trailblazer SS manifolds even if I was a couple of inches higher or lower. My engine is installed closer to the 2WD location instead of the 4WD location to accomodate my longer 4L60. If the engine was moved closer to the firewall there would be even more room.
I have stock truck manifolds and Fbody manifolds. I had read that the SS manifolds worked great, I found a set and never even tried any of the others.
Old 09-08-2010, 09:24 PM   #10
TR65
TR65's Avatar
I am running 2005 SSR manifolds in my 65. Same as Trailblazer SS I believe. They hug the engine and mount without any interference including the stock heat shields.
I am mounted 1" forward of the original 283 for rear space and 5/8" higher for pan clearance.
I am running the stock SSR engine mounts on fabricated perches off the crossmember, so they are out of the way of everything.
Here are some pictures from the final test fit. On the road now.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 09-08-2010, 10:46 PM   #11
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
My LY6 manifolds didn't fit with the ECE mounts...but the new ones I plan on using will move the motor back far enough that I think they are going to fit. Won't matter much as I plan on using headers.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-11-2010, 10:04 PM   #12
OKGMC4
OKGMC4's Avatar
I also have a 56 and I'm using corvette LS1 manifolds on my 5.3. They fit great for me...
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
