Old 09-14-2010, 11:43 PM   #1
ANDREW
front coil help
so i put my stock suspension back on rear was flipped and the front had drop coils i got the back done to day but it sits really high i know that the rear from factory was higher my question is how much to i have to raise the front to level it out im putting my stock coils back but i know that wont cut it
ANDREW is offline   Reply With Quote
Old 09-14-2010, 11:51 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: front coil help
Try a set of C20 coils. They might get you close to level.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-15-2010, 12:08 AM   #3
ANDREW
Re: front coil help
sorry for got to mention my truck is a 1983 chevy c20 2wd
Old 09-15-2010, 12:11 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: front coil help
Hmm, maybe a C30 coil then. I'm not much of an expert on lifting them. Ask me how to lower and I got ya covered.
Articles-
"Refining Sierra"
Old 09-15-2010, 12:12 AM   #5
ANDREW
Re: front coil help
i just want to level things out front and rear
Old 09-15-2010, 12:48 AM   #6
ANDREW
Re: front coil help
anyone know what i should do?
Old 09-15-2010, 03:42 AM   #7
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: front coil help
Install a 2" shackel. The rear is 2" higher from the factory. Shackels are cheap. You could also flip the front hanger. Flipping the front hanger may drop it more than 2".
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 09-15-2010, 11:06 AM   #8
ANDREW
Re: front coil help
so if i install a front 2" coil spacer id be good too
Old 09-15-2010, 11:17 AM   #9
Prerunner1982
Prerunner1982's Avatar
Re: front coil help
I think a 1ton/diesel front coils would bring the front up if you have a gas 350..
My 1/2ton 2wd sat level with only 1ton front coils.
Also... you do not want to put a 2" spacer on the front coils. Due to geometry all you need is about a 3/4"-1" spacer to get 2-2.5" of lift.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 09-15-2010, 04:32 PM   #10
gchemist
gchemist's Avatar
Re: front coil help
No drop the rear. It's easier.
Old 09-15-2010, 04:45 PM   #11
Prerunner1982
Re: front coil help
No.... lift it it looks better.
Jon
Oklahoma Roll Call
Old 09-15-2010, 10:56 PM   #12
ANDREW
Re: front coil help
ok guys i only wanna do this once how much of a lift spacer with my stock spring do i need to level it out
Old 09-15-2010, 11:10 PM   #13
Matt Man
Matt Man's Avatar
Re: front coil help
put heavy duty 1 ton coil springs with a 1 inch spacer. worse case scenario you need to add a block in back...
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 09-16-2010, 12:18 AM   #14
ANDREW
Re: front coil help
i just want to get a coil spacer just dont know witch size
Old 09-16-2010, 01:37 AM   #15
ANDREW
Re: front coil help
Bump
Old 09-16-2010, 03:14 AM   #16
Matt Man
Matt Man's Avatar
Re: front coil help
than i would say 2 inch spacer. make sure your balljoints are in good shape.
Old 09-16-2010, 08:45 AM   #17
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: front coil help
2" drop shackles
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 09-17-2010, 12:05 AM   #18
ANDREW
Re: front coil help
Ok so im going to get a 2" coil spacer for the front any heads up while installing my old coils back
Old 09-17-2010, 12:20 AM   #19
Matt Man
Matt Man's Avatar
Re: front coil help
to be honest just buy 1 ton coils while you have the springs out.... still put the spacer in, besides that just be careful with coil springs.
Old 09-17-2010, 12:22 AM   #20
ANDREW
Re: front coil help
why get 1 ton coils ?
Old 09-17-2010, 01:16 AM   #21
Matt Man
Matt Man's Avatar
Re: front coil help
because they have a higher spring rate and it will make the truck sit taller.
Old 09-17-2010, 02:04 AM   #22
ANDREW
Re: front coil help
well if i only need 2" and im putting 2" coil spacers if i put the 1 ton springs id be to tall
Old 09-17-2010, 05:34 AM   #23
LONGHAIR
Re: front coil help
"Lifting" a 2wd truck is not as easy as it has been made to sound. There is only so much "droop" travel in the front suspension to begin with and adding coils spacers w/o taking this travel limit into account is a problem. I wouldn't bet on the 1 ton springs doing much more than making the ride unbearable.
You really are better off to lower the rear to match the front with the new "stock" coils up front.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-19-2010, 10:14 PM   #24
ANDREW
Re: front coil help
ok guys so i dropped the lower control arm and i compressed the spring and tryed to shove the spring in but it just seems i cant compress the spring enough im stuck and need some help any one have tips and even if i do compress the spring enough i just cant get the compressor out
Old 09-19-2010, 10:37 PM   #25
ANDREW
Re: front coil help
anyone i need help guys
