Old 09-19-2010, 11:35 AM   #1
dman1982
dman1982's Avatar
Question mph question???
i put 35's on my truck how do i get the mphs to be correct...its about 5 or so mphs off now...how do i fix this? 84 k10 4x4
dman1982 is offline   Reply With Quote
Old 09-19-2010, 07:34 PM   #2
dman1982
dman1982's Avatar
Re: mph question???
does anyone know????
Old 09-19-2010, 07:53 PM   #3
C-10 simplex
Re: mph question???
If you'll give me a minute, i have i link to an exasperating, exhaustive, drawn out drama of my own concerning this very dilema that i went thru-----i usually make things more difficult than nessesary for some reason.
C-10 simplex is offline   Reply With Quote
Old 09-19-2010, 08:17 PM   #4
LONGHAIR
Re: mph question???
It's a simple matter of changing the driven gear that is inside the tailshaft of the transfercase. It is the square hole that drives the speedometer cable.
You will see a small bolt and forked clamp that hold in a circular "plug". When you remove the clamp the entire "plug" will pull out. The gear is on the end of it. Simply pull it off and take it to the dealer. They are color coded to display the tooth count. It helps to know where you are starting from, to determine which one you need.
Cheap easy fix, unless you are waaay off, which you shouldn't be at this point.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-19-2010, 09:01 PM   #5
dman1982
dman1982's Avatar
Re: mph question???
hey thanks guys
Old 09-19-2010, 11:53 PM   #6
BigRed76
BigRed76's Avatar
Re: mph question???
Don't mean to steal this thread, but i will soon be putting 35" tires on my truck, and have been doing some research on the speedo gear thing, and my t-case has a ratio adapter on the speedo gear right now. Does this ratio adapter need to be replaced with a different one or should i ditch the adapter all together and just replace the driven gear on the t-case?
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
mph
