Old 09-22-2010, 09:46 AM   #1
53chevyforever
53chevyforever's Avatar
53 gmc cowl vent leaks need help!
Is there anyone who has had this problem and knows how to adjust to stop it...have a new gasket and everything looks fine...but water just pours in around the vent at the back portion...any help would be appreciated...about to the point to seal it completely.
53chevyforever is offline   Reply With Quote
Old 09-22-2010, 09:55 AM   #2
mr48chev
mr48chev's Avatar
Re: 53 gmc cowl vent leaks need help!
Is the drain tube clean and working? a lot of guys who "clean up the firewall" eliminate the drain tube from the vent that goes through the firewall and the water ends up dumping on the floor. I haven't played with one in years to try and adjust it so I'm not much help there at the moment.
Old 09-22-2010, 09:57 AM   #3
53chevyforever
Thanks for answering...yes vent tube is clear...it just seems that when lowering the vent it contacts the front before the rear..and I can find no adjustment to correct it?
Old 09-22-2010, 10:12 AM   #4
WIDESIDE72
WIDESIDE72's Avatar
Easy. Just don't drive in the rain! Seriously, though sorry I can't help.
WIDESIDE72 is offline   Reply With Quote
Old 09-22-2010, 02:58 PM   #5
raycow
How about building up the gasket in the rear - maybe put some kind of shim or spacer under it?
Ray
raycow is offline   Reply With Quote
Old 09-22-2010, 05:57 PM   #6
53chevyforever
Mmm...tried that and no help...its almost like the bottom gasket is too short..I looked in classic and it shows a foam gasket that was supposed to be original and then aftermarket....I think mine is aftermarket rubber...so thinking of trying the orignal type one next...Tim
Old 09-22-2010, 09:10 PM   #7
solidaxel
solidaxel's Avatar
I tried a few of them and ended up using the one from Steele Rubber and it seems to seal the best.
I am sure you had all of the bolts out and adjusted it to fit and make sure the lever was over center. I ended up putting a electric motor on mine to open and close the vent and it seemed to help with the pressure to hold the vent down.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-22-2010, 09:25 PM   #8
53chevyforever
Yes..tried all adjustments...afraid to go tighter or bend hinges etc...I found the steele rubber site...got another brand on the way...if it does not work..will try your suggestion...thanks...Tim
