Old 09-24-2010, 09:34 PM   #1
baclay9
Diesel radiator fitment???
I found a radiator that came off of an 85 k3500 that had a 6.2 L diesel in it. Should that be a big 4 core radiator? I am needing one for my 454 conversion. Any info is appreciated.
baclay9 is offline   Reply With Quote
Old 09-24-2010, 09:48 PM   #2
baclay9
Re: Diesel radiator fitment???
Sorry, it is going into a 83' c10. I have a radiator top bracket for a 4 core so I assume it will work with the diesel radiator..
Old 09-24-2010, 09:56 PM   #3
Stitch
Location: Where I come from, it's cornbread and chicken...
it should be a 4 core big radiator...just make sure you get the radiator hold down on the top...it's the big plastic piece...lol
Stitch is offline   Reply With Quote
Old 09-24-2010, 09:59 PM   #4
irishman999
irishman999's Avatar
The inlet is the only difference if i remember right. Our diesel parts suburban donated its radiator to a 454 and all seem fine, I put the 454 radiator back in the suburban and it worked fine, i just made a custom redneck upper radiator hose.
irishman999 is offline   Reply With Quote
Old 09-24-2010, 10:26 PM   #5
baclay9
I have the metal hold down piece off of a 4 core radiator. Is that the pice you are talking about?
Old 09-24-2010, 11:18 PM   #6
Stitch
I'm talking about the plastic piece on top that says 'caution fan' on it
Old 09-24-2010, 11:32 PM   #7
baclay9
I am going to be running dual electric fans so I shoudn't need the shroud right? Am I thinking right that the diesel radiators are even bigger (wider) than the regular 4 core big block radiators?
Old 09-25-2010, 09:33 AM   #8
baclay9
Hey Stitch. I just have the upper radiator support for a normal BBC 4 core radiator. Are you saying I will need a different upper support to make the diesel radiator work? I have never seen one before so I have no point of reference.
Old 09-25-2010, 12:37 PM   #9
Stitch
I'll take a picture of mine for ya...I think you just need the regular upper support...
Old 09-25-2010, 12:38 PM   #10
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
so a 1 Ton 6.2 has 4 core rads?
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 09-25-2010, 12:50 PM   #11
Stitch
Here's the pictures...the first pic is of the passenger side hold down...the second pic is of the driver side hold down...the third pic is of the other set of holes for mounting the regular 4 core radiator hold down...the diesel radiator I think is wider than the normal 4 core radiator...you're gonna need the plastic piece that goes across the top of the radiator to make it look right...it bolts to the core support and shroud...a normal piece is not going to be wide enough...the fourth picture is of the plastic upper piece...the fifth and sixth pictures are of the inlet and outlet...on the driver's side is on the top and on the passenger its on the bottom...
Old 09-25-2010, 12:51 PM   #12
Stitch
every 6.2 should have a 4 core radiator...actually it's wider than a normal 4 core radiator that would come with a big block I'm pretty sure...mine's a 1.2 ton and it has a 4 core
Old 09-25-2010, 12:53 PM   #13
GmtGmt
GmtGmt's Avatar
cool
Thomas
Old 09-25-2010, 03:12 PM   #14
baclay9
The one I just looked at also had a built in oil cooler. I didn't end upmbuying it. It was pretty ruff. The search continues.....
Thanks for the pics Stich
Old 09-25-2010, 07:34 PM   #15
Stitch
No problem. And yeah they have ab oil cooler built in to help keep the motor cool
Old 09-26-2010, 12:26 AM   #16
joe231
joe231's Avatar
Hey Brandon,
I have a BBC 4 core radiator from a '78 that you can have if you want it. I think it might have a hole in one of the tubes though. I dunno what it would cost to have repaired.....
CHEVY ONLY
Old 09-26-2010, 12:35 AM   #17
baclay9
I'll take it Joe. I was going to take whatever I got into the radiator shop anyway. This will be better than buying one from someone and then finding out it has holes all in it anyway. Are you going to be around tomorrow?
Old 09-26-2010, 12:38 AM   #18
joe231
joe231's Avatar
yes sir
should be
Just give me a shout
CHEVY ONLY
