anybody run a 10" wide wheel with a 7" drop?
hey just wondering if anyone on here has a 7" drop in the rear of their truck and running a 10" wide wheel, what size offset do you have? what size tire are you using as well?
I want a wider tire but the sidewall is pretty close to the lip of the wheel well, looks like theres a couple inches to go before rubbing the leafs. so to go wider would be more offset? I was thinking of mini tubbing the box to get more room but seems like a lot of offset for a rim? any pics? |
Re: anybody run a 10" wide wheel with a 7" drop?
after hours of searching i found a 15x10 will work with atleast 4.5" backspace, im gonna go with 5" backspace so i can mini tub the box a bit and get the biggest tire in there possible.. anyone know what it would be? i'll have to get the rim and measure it out one the truck
i search lots more last night and found wheel vintiques makes a 15x10 rally with a 5" backspace so thats what i'll be going with
.. !WAR FEDOR! ..
here are some wheel vintique rallies, 15x10 with 5'' of b/s. the drop is about 6.5, running a 295/50r15 at the time.
"san diego chargers #1" |
.. !WAR FEDOR! ..
sorry , the lower pic is the one with th lower drop, i accidently added the first one.
that looks good thanks! Does it stick out any farther than a stock 8" rally wheel? Thats my main concern because the 8" with the tire i have on its very close to the inner lip of the wheel well but if i need to ill just trim it off
thanks again |
Badass
My back tires stick in alot more then the front
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90
.. !WAR FEDOR! ..
thanks, my front wheels are 8'' with 4''s of b/s, they are flush with the rear 10'' wide wheels. thats why i got 10''s with 5''s of bs on the rear, to make up for the whole track width thing, they sit just inside the fender. i can squeeze in about a fender
"san diego chargers #1" Last edited by joe1982; 09-28-2010 at 05:17 PM. |
awesome thanks! what about to the leaf springs? any idea how close they are? or how close the tire is to the inner wheel tub?
My 74 has a flip-kit w/some drop shackles on the 8-leaf spring pack. I've ran 2 different 10" width wheels in the rear. I had 20x10" w/5.00bs & 295-40's & 20x10's w/5.50bs & 295-40's.
Although both physically fit, the 5.00bs offered better clearance.
in for the same info, thanks
1979 c30 3+3 dually 1946 GMC |
| Bookmarks |
