Old 10-15-2010, 06:52 PM   #1
SiCk_DiAbLo
SiCk_DiAbLo's Avatar
Cheap lowering idea's??
Got a 79 Chevy shortbed, but don't really wanna spend alot of money on it..Since it's gonna sell...Any cheap lowering idea's??...Thanks!!!
1993 Chevy Silverado.
1984 Chevy Z28.
1972 Chevy Custom 10.
1965 Custom 10..FOR SALE
SiCk_DiAbLo is offline   Reply With Quote
Old 10-15-2010, 06:56 PM   #2
joe231
joe231's Avatar
Re: Cheap lowering idea's??
cut a coil in the front and remove a couple leafs in the rear
CHEVY ONLY
Old 10-16-2010, 01:26 AM   #3
chevyman95
chevyman95's Avatar
How much lower would that go?
chevyman95 is offline   Reply With Quote
Old 10-16-2010, 02:14 AM   #4
nbpro
Suspension >>> http://67-72chevytrucks.com/vboard/f...splay.php?f=25
nbpro is offline   Reply With Quote
Old 10-16-2010, 04:34 AM   #5
irishman999
irishman999's Avatar
Bags of concrete.
irishman999 is offline   Reply With Quote
Old 10-16-2010, 07:22 AM   #6
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Originally Posted by irishman999 View Post
Bags of concrete.
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 10-16-2010, 09:58 AM   #7
joe231
joe231's Avatar
@ 2" of drop for each coil cut off and it depends on how many leafs the rear pack has to begin with.
CHEVY ONLY
Old 10-16-2010, 01:28 PM   #8
80chevyshortbox
80chevyshortbox's Avatar
i picked up 3 inch lowering springs shackles, hangers and all 4 lowering shocks for 400 bucks of ebay. which will allow a 3/4 drop.
80chevyshortbox is offline   Reply With Quote
Old 10-16-2010, 01:49 PM   #9
flamingbig10
6.0 powered square
flamingbig10's Avatar
I had one cut coil removed a few leafs and drop shackles. It was only $50 bucks for drop shackles and a new center bolt to hold the leafs together
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 10-16-2010, 04:17 PM   #10
chevyman95
chevyman95's Avatar
Looks like I only have 3 leaves and an add a leaf looking thing on the back right now, what can I remove? Or should I? I don't want to do anything dangerous. Thanks
Old 10-16-2010, 05:05 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Up front, cut one coil. In the rear, remove the rivits from your spring hanger and move it up. All it costs is the labor and a few grade 5 bolts.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-16-2010, 05:34 PM   #12
nbpro
Thats how i did mine post 34
http://67-72chevytrucks.com/vboard/s...=323014&page=2
Old 10-16-2010, 08:00 PM   #13
ChevyGearHeads
Check out me and my son's youtube profile ChevyGearheads we put lowered shackles and cut off the top half of the hangers.
I hope this is helpful...
ChevyGearHeads is offline   Reply With Quote
Old 10-17-2010, 12:57 PM   #14
willett
Another Day, Another Dollar
willett's Avatar
now i've never done it and i'm unsure of any asscociated safety risks, but isn't it possible to heat your coils with a torch and let the weight of the vehicle compress them?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 10-17-2010, 02:48 PM   #15
irishman999
If I remember right, heating the coil is not controlled enough and you end up with different spring rates on all four corners.
Old 10-17-2010, 03:02 PM   #16
mooseknuckles
mooseknuckles's Avatar
If you can do all the work yourself......Flip kit in the rear end, practically free. cut a coil on the front springs, and drop spindles. You can buy used spindles. mine were $400 new( bell tech). 4/6 drop.
mooseknuckles is offline   Reply With Quote
Old 10-17-2010, 03:38 PM   #17
jasonroman
jasonroman's Avatar
cheap sounds good to me.
but then again, i have decided to wait till i have 400 extra bucks laying around to buy a kit that has everything needed to lower truck 4/6.
im sure cutting a coil and blocks for rear are a cheap way that will show a little lower truck. but the reality is the truck will prob ride like crap and not be low enuff for my liking. so as opposed to going quick and cheap, im gonna wait it out and get a kit when the extra cash is available.
i think i read your gonna sell truck soon anyway, so i guess it dont matter.
good luck either way.
jasonroman is offline   Reply With Quote
Old 10-17-2010, 07:07 PM   #18
benoit454
Chris
benoit454's Avatar
blocks will raise the truck, you need to do a flip kit before blocks will work.
You can buy the flip kit brackets on ebay for less then $50 and that'd get you 5-6 inches of drop. You could add blocks, hangers or shackles to that to make it lower.
Summit has 1,2, and 3 inch drop springs, the 3 inch are like $75. if that aint low enough not sure if you can cut them off or not, maybe get the 1 or 2 inch drop springs and cut some of them? Cutting them usually makes it stiff and I think taking leaves out makes it bouncy or spongy?
Buy the drop spindles, or a arms, then cut the stock coils to what you want.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 10-17-2010, 07:44 PM   #19
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
You can also flip the front leaf hanger.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 10-17-2010, 09:42 PM   #20
jasonroman
jasonroman's Avatar
only said blocks cause i used them to lower a corolla once
sorry for bad info was just trying to make sum what of a point
Old 10-17-2010, 11:25 PM   #21
mooseknuckles
For me I knew that a 4/6 or 5/7 drop was never going to be enough, I was planning right from the start to bag my truck, years before I even bought it. I wasn't wasting money on lowering springs, but I knew that I would need drop spindles later on, so I bought them first. I did the flip in the rear without a kit, and raised the spring hangers up by myself, 0$. Eventually the back end will be 4 linked and bagged, the front is already. For the little extra money it costs you can bag the front right from the start! you don't even need the spindles yet. I have mine run off a schrader valve for now till I get tanks and a compressor. but it is completely adjustable, with a low static drop it's a ***** trying to jack it up to work on and there's some places where you just can't go...
Old 10-17-2010, 11:57 PM   #22
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
For the rear, you can use the 81-91 suburban hangers. 1 out of the 4 holes bolt up lol, and the other 3 ... well just make new holes... its the equivelant to the $$ aftermarket lowering hanger.
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
