Badass
temp switch
the temp switch that is in the head. i have the one off my 305 going onto my 400 and the hole is bigger on the 400 head so it wont fit the senser. is there a adapter or a bigger temp switch i use?
also. i need a plug the same size for the other head. thanks
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90
Re: temp switch
Yes you can use an adapter, you must have an aftermarket gauge do you . I thought all temp sending units were the same size until you got into the newer stuff
Badass
Re: temp switch
It's out of a 84 305 going into a 72 400 so the years are apart. And where could i get a adaptor? Summit?
Re: temp switch
The temp. sending units are both pipe thread one id 3/8's NPT and the 400 uses 1/2 NPT. You can go to any store that carries plumbing stuff and get an adapter to make it work. Here is what to look for
Badass
Re: temp switch
yup thats what i got. it was like 2.50
use that white piping tape one the threads right?
Re: temp switch
look for some high temp stuff to seal the threads
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
Badass
Re: temp switch
Too late it's all already in. Along with other parts with white tape
| Bookmarks |
