10-29-2010, 03:49 AM | #1 |
V6 4.3L (262) on a 73 jimmy engine support question
Hi, I have a GMC jimmy 73, I want to know if I need to modify the supports or something else If I put a chevy 4.3 engine in my jimmy, my jimmy original config was 350 v8 (lost, long time ago) + SM465 + NP205 (4x4)
------------------------------------ 1988 Ford taurus LX SW V6 3.0L vulcan - Axod 1973 GMC Jimmy Sierra 4x4 L6 diesel nissan LD28 (temporal engine) |
10-29-2010, 08:48 AM | #2 |
Re: V6 4.3L (262) on a 73 jimmy engine support question
you won't have to modify anything should bolt right in.4.3l v6's are just 350's with the two front cylinders missing.
R.I.P gm 1908-1986 1982 chevy k20,350,sm465,np205,10bolt and 14bolt s.f |
10-29-2010, 12:31 PM | #3 |
Might have to do something with the rad shroud, you're going to be a bit farther from the rad with the fan with a 6-banger.
All Chevy V-8's are the same distance from motor mount holes back to the bellhousing flange, anything extra or less is in front of that point. |
10-29-2010, 01:12 PM | #4 |
thats right, for that reason, I will replace the original fan with an electric fan (termoswitch activated)
04-09-2011, 02:53 PM | #5 |
Did you ever get that V6 in? I have a 4.3L fuel injected engine I'm putting into a 72 C-10 truck, and was curious about the motor mounts. I'm sure I can figure it out, but I was wondering if you already installed your engine and if you had any issues.
