Old 11-07-2010, 08:52 AM   #1
kgmunro
Bodywork Question
I am pulling the cab off my 57 gmc for bodywork. But if I am setting door gaps and welding in panels (rockers,steps) does the truck cab need to be on the frame or can it just be blocked up till it's level??
kgmunro is offline   Reply With Quote
Old 11-07-2010, 10:17 AM   #2
Knothead
Knothead's Avatar
Re: Bodywork Question
I would do all your alignments with the cab on the frame. I also recommend using mounting pads that will be used when finished.I did mine of the frame and one door doesn't fit as well on the frame.
Knothead is offline   Reply With Quote
Old 11-07-2010, 10:40 AM   #3
contracostastepside
Definitely on the frame. I have a 57 gmc as well. Doesn't seem to be very well represented here. I just got mine.
contracostastepside is offline   Reply With Quote
Old 11-07-2010, 03:00 PM   #4
Mr GMC
Mr GMC's Avatar
I did a cab off the frame. The owner of the cab dropped it off to me bolted down to a rolling cart that was made to fit it. I replaced the inner and outer cab corners steps, hinge pockets and worked the doors. I only did the metal replacement and door alignment. It left for body and paint elseware and when the truck was finished the doors still fit the cab. Here is the truck I helped work on.
Uploaded with ImageShack.us
Mr GMC is offline   Reply With Quote
Old 11-08-2010, 04:28 AM   #5
seeso
seeso's Avatar
Hi, since your on this subject... quick question, Do you start at the hinge pocket and work back if you have most of the lower cab to replace?
Thanks.
seeso is offline   Reply With Quote
Old 11-08-2010, 10:58 AM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
I start at the step and work forward. Replace the step, then the hinge panel then the inner and outer pockets, then the corners if needed. It’s important to measure prior to cutting out pieces. So you know how they line up before welding them in.
The reason I start at the step is there is a cross beam under the floor that attaches to the rear lower pillar panel. This is a very solid area and its fixed and doesn't move during the replacement process, if you work from that point forward everything is measured from there rather than a point that may or may not line up in the front at the pillar pockets and hinge panel that can shift when cut out.
Everyone has their own way of doing this and as long as it works out it’s not the wrong way just different.
dwcsr is offline   Reply With Quote
Old 11-08-2010, 12:41 PM   #7
OrrieG
OrrieG's Avatar
If you are replacing the step, hinge pocket and corners I would throw is some temporary bracing to keep the cab in alignment. Dave is right his sequence is the same one used during assembly at the factory, the step goes in first and all the other pieces spot weld over it.
Mr. GMC, what size wheel are you running and what model of caps and trim rings. I want to use my 74 16" steel wheels with caps and rings like yours but am having trouble finding them. Thanks
OrrieG is offline   Reply With Quote
Old 11-08-2010, 01:53 PM   #8
cajundragger
shim your cab mounts.
cajundragger is offline   Reply With Quote
Old 11-08-2010, 03:20 PM   #9
seeso
seeso's Avatar
Thanks, for the info guys, I'll plan it that way. I have floorboards patch panels from the seat riser to partially up the toe board too.
Old 11-08-2010, 05:14 PM   #10
jimig1
jimig1's Avatar
Post some pics everyone likes to the the progress
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 11-08-2010, 06:03 PM   #11
dwcsr
Hollister Road Co.
dwcsr's Avatar
I used an old frame and chopped the ends off and then welded some wheels on it. Makes for an easy to move and work around rig. That way its on the original mounts and you can bolt it down.
Old 11-08-2010, 09:46 PM   #12
seeso
seeso's Avatar
That is a Slick set up right there.
