Old 11-14-2010, 05:14 PM   #1
HSkinner
How to properly plumb my air bags
Any good write ups on the best way to plumb a complete air ride set up, valve locations, tank locations fittings etc.. thx
HSkinner is offline   Reply With Quote
Old 11-14-2010, 05:43 PM   #2
62 Bowtie
62 Bowtie's Avatar
Re: How to properly plumb my air bags
yeah i'd like to know too there are threads in suspension about wireing but not plumbing
62 Bowtie is offline   Reply With Quote
Old 11-14-2010, 06:12 PM   #3
shortbed70
shortbed70's Avatar
Best way is to have the valves as close to the bags as possible and straight lines are your friends try to keep 90 degree fittings to a minimum.As far as tanks anywhere is a good place just make sure you have a bung in the bottom of the tank to drain off access water that builds in them. My valves for my 65 will be mounted on the inner fenders directly above the front bags and the rear will be mounted under the bed above the bags. My tanks are mounted under the drivers and passanger compartments with 1\2" line to the front and 3\8" to the rear. As far as fittings push to connect are the best way to go in my opinion.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
