Old 11-15-2010, 08:27 PM   #1
scum1
scum1's Avatar
Old vs new front end
Lookin at a truck for sale that has disk brake up front, 5 lug. he got it like that from the PO, so how do i know whether the front end was swapped from a late model or if it just got a disc brake kit from xxx. what would be a giveaway? trucks a 63 btw thanks in advance
scum1 is offline   Reply With Quote
Old 11-15-2010, 08:33 PM   #2
creep
Registered Loser
creep's Avatar
Re: Old vs new front end
Maybe the lower control arm bushings? I know the earlier trucks had steel bushings, but I'm not sure when they switched to rubber.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 11-16-2010, 12:55 AM   #3
scum1
scum1's Avatar
ok the front crossmember will look the same, but if it has rubber bushings for the control arms it will be a swapped end im just doing all this for the chance that i buy this, what spindles will i need..the 63 drop or the 73-87 drop or whatever..ill post more on this in the even any of this takes place
Old 11-16-2010, 01:49 AM   #4
Captainfab
60-66 Nut
There are a few ways that a disc brake conversion can be done. If you're thinking of switching to a drop spindle, the best thing to do is post a pic or two of what the truck has, and then we can determine what the parts are.
Old 11-16-2010, 06:53 AM   #5
raycow
This isn't 100% guaranteed, because you can get some oddball tie rod ends if you look hard enough, but it will work if the builder used stock parts. Measure the thread diameter (at the adjusting sleeve) on the outer tie rod ends, Factory disc brake spindles will be 11/16". Aftermarket conversion spindles will be 5/8" because they use the stock early tie rods.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
