Old 11-16-2010, 10:10 AM   #1
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Budget minded front shocks
Im looking for replacement front shocks for my truck. The truck is lowered a few inches in the front so I probably need a shorter shock. The length sitting still is 11". Im thinking of one that will go from 8.5" to 12.5" of travel. I really dont want to spend more that $20 per shock.
Thanks for the help.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 11-16-2010, 10:21 AM   #2
badriand
badriand's Avatar
Re: Budget minded front shocks
You may have luck with the monroes 33033's.. or the # may be 333033 but they had less travel then i have now but several people use them. If that doesnt work you may have to use some shock relocaters that way you can use the cheaper stock type shocks. I found out that i am just going to have to fork up the cash and buy some drop shocks from belltech or someone. I currently have like 1 1/2 inchs of travel before my front ones bottom out but it seems to be ok as i don't go too fast down the back roads anyway and on open road they ride great.
badriand is offline   Reply With Quote
Old 11-16-2010, 10:24 AM   #3
61_FL_Apache
Who Me?
Cash is short and my shocks are shot. I can do Belltechs next time.
Steve
2001 Blazer 4D 2WD
Old 11-16-2010, 12:35 PM   #4
61_FL_Apache
Who Me?
Thanks John. I found that site eariler and it has a lot of good into, maybe a little too much info.
What is the difference between the shocks of a 60-62 and 63-66? I can find cheap shocks for a 65, but the 61's were much more $$.
Steve
2001 Blazer 4D 2WD
Old 11-16-2010, 12:53 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
The only difference between the stock FRONT shocks is a steel sleeve in the upper bushing on the 60-62 version. This prevents the bracket from collapsing. The 63-72 shocks mount on a shoulder stud, so the steel sleeve is deleted. If you have old 60-62 shocks, just press out the sleeve and put it in the later version, it fits perfectly. I'm running 63-72 shocks in the front of my 1960 using this method.
Old 11-16-2010, 01:53 PM   #6
61_FL_Apache
Who Me?
Gotcha! I just picked up a set of Monroe Gas-matics LT for $22 each. They are for a 65.
Steve
2001 Blazer 4D 2WD
