Old 11-23-2010, 08:48 PM   #1
TheSeeker
Oil change time!
Hey all, its time for me to change the oil in my truck, however I am not sure what weight to buy. Its an old worn out 350 and I wasn't the one who did the last oil change. And sadly my grandfather (the PO) is not with us to ask hahha. What would be a safe bet to buy? Thx
TheSeeker is offline   Reply With Quote
Old 11-23-2010, 08:56 PM   #2
BearFlagRepublic
Re: Oil change time!
I've always used a standard 10-W40 in 350's.
BearFlagRepublic is offline   Reply With Quote
Old 11-23-2010, 09:07 PM   #3
sameyrasmea72
sameyrasmea72's Avatar
I use rotellaT. I think it is for diesel engines but several people have convinced me it works wonders on old tired 350's. I think it has extra zinc in it. My mechanic who has been building big blocks for us since the 1970’s was adamant that I even use it on the 468 he just built me to break it in. Then he said to go with a synthetic oil after about 10,000 miles.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 11-23-2010, 09:09 PM   #4
TheSeeker
That's what I was going to buy, but a cousin of mine said 20w 50 so I thought I'd ask haha.
Old 11-23-2010, 09:18 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
20w50 isn't a bad choice if the motor is worn. I'd add some ZDDP Plus as well.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 11-23-2010, 10:23 PM   #6
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I use Rotella -T also. It's 15w40. Works great on older engines.
--Josh
Old 11-23-2010, 10:31 PM   #7
LandonL
LandonL's Avatar
Castrol Syntec 20w-50 for classic cars that have a flat-tappet camshaft. It's what I put in my 250L6. Supposedly has plenty of zinc for the cam.
---| 1967 GMC Stepside |--
250 L6 .030 over
---| 1985 Porsche 944/1 |---
Build Thread: '67 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=378640
LandonL is offline   Reply With Quote
Old 11-23-2010, 10:47 PM   #8
Bad70sbchevy
Bad70sbchevy's Avatar
I run 20W-50 VR1 in mine. Has a lot of zddp content. I previously ran SAE 50 with no problems.
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 11-24-2010, 08:31 AM   #9
jondancer
how many quarts?
jondancer is offline   Reply With Quote
Old 11-24-2010, 10:44 AM   #10
mrein3
mrein3's Avatar
10-W40, 15w40, 20w-50, HOLY HANNA!
I notice all you guys are down south. Up here I run 10w-30 in all my V8s. Summer and winter.
That heavier stuff might not even allow your engine to turn over on a cold morning up here. You might even end up with a spun bearing.
I guess I should say not all my V8s run on 10w-30. The 2004 Explorer with a V8 calls for 5w-20.
Seriously. I'd be concerned about running that heavy of an oil where it gets cold.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 11-24-2010, 02:16 PM   #11
DT1
DT1's Avatar
Originally Posted by jondancer View Post
how many quarts?
Five
DT1 is offline   Reply With Quote
Old 11-24-2010, 02:24 PM   #12
timjt
Only 5? my camery takes 5.
2001 silverado stolen by family
1983 short n wide custom deluxe SOLD
1985 silverado longbed 305 engine 700r4
OH NO! NOT ANOTHER LEARNING EXPERIENCE!!!
"Just because you can do it, doesn't mean that you should"
timjt is offline   Reply With Quote
Old 11-24-2010, 02:50 PM   #13
don t. - 72gmc
When I saw 50wt, first thing I did was look at location. Yep, warm places.
I run 50wt non-detergent in my 45 2N ford tractor that needs a rebuild. In winter I change to 20w.
I run valvoline 10w30 in my 70(396bb) and 72(350sb).
Wifes chevelle w/a rebuilt 327 gets mobil-1. It don't leak(grin).
Have fun....don t. ....
don t. - 72gmc is offline   Reply With Quote
Old 11-24-2010, 05:14 PM   #14
cam.man67
cam.man67's Avatar
I use whatever I got at the farm. Usually 10w30, sometimes 10w40 or 5w30, I hear hydraulic fluid works well to clean out the crankcase.
In other words, I'm not concerned with getting the highest quality oil in my motor. My motor is not nearly high-stress enough or used in high-stress applications enough to justify the expensive stuff. Nor is is it stock, so I don't have to worry about ruining an original motor.
'68 Dodge Dart 270, 225, 904, 2.76--"Lucy"
1996 Gmc 1500 Z71, 350, 4l60e, 3.73s
1995 Jeep Wrangler Rio Grande 2.5, AX5, 4.10s
1989 Toyota Pickup 22re, auto, 3.73
cam.man67 is offline   Reply With Quote
Old 11-25-2010, 02:19 PM   #15
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
don't bother with the diesel oils (rotella) they now have LESS zink than the normal car oils.
Old 11-25-2010, 03:22 PM   #16
cdowns
cdowns's Avatar
when i lived up in new york i always ran 20-50 in my older himilage vehicles and never had a problem with it for over 35 years of drivin them like that
Old 11-25-2010, 07:44 PM   #17
piecesparts
Parts and more parts
piecesparts's Avatar
The Rotella T used to have zinc in it, but in the last year or so, the manufactuerers are rumored to have removed it. That is so they could meet the Federal requirements and continue to sell it. The additive is a necessary item for wear limitations on things like cam lobes and lifters.
I would say that your oil change depends on where you live and what temperatures you will be experiencing in the near future. Heavy weight oils is hard to move in cold temps, so many manufactuerers recommend a lighter weight oil in the winter months. GM will only warranty oils that are 5w30 weight in their newer cars, it is an all around oil weight for daily driving.
I run a 10W 30 oil year around and let my vehicles warm up slowly in the cold months, to limit abuse. My DD has just turned over 301,000 miles and is still running strong. I run a friction additive (Energy Release) in my oil pans and I believe that it has helped me get longevity out of my engines---I may be wrong, but it is my choice. I use Trop Artic oils, since I used to work in a county highway department shop and saw the inside of a lot of high mileage engines and how clean they were. The price on it is about as good as any and it works for me.
Frank
piecesparts is offline   Reply With Quote
Old 11-25-2010, 08:14 PM   #18
treveiger
treveiger's Avatar
This is what im planning on putting in my truck next year says zink right on the bottle. Just a thought.
http://www.amsoil.com/storefront/amo.aspx
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 11-25-2010, 08:20 PM   #19
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
+1 for Valvoline VR1.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 11-25-2010, 08:24 PM   #20
QKENUF4U
QKENUF4U's Avatar
Thumbs up Re: Oil change time!
being your in phoenix just run a 5 or 10w30 for the next couple cool months and youll be ok.. when it turns up the heat then jump to 20w-50 for some better protection...
That heavier stuff might not even allow your engine to turn over on a cold morning up here. You might even end up with a spun bearing..
if ya spin a bearing then it aint from the oil... the W stands for winter so if its 5w/10w then it shouldnt have a problem flowing in winter temps.... if you run straight 50 weight then yes i can see a problem...
QKENUF4U is offline   Reply With Quote
Old 11-26-2010, 12:23 AM   #21
sameyrasmea72
Originally Posted by piecesparts View Post
The Rotella T used to have zinc in it, but in the last year or so, the manufactuerers are rumored to have removed it. .
Could be! I have heard the rumor too. But I don't think they have done it yet. I just spent $6000 on a rebuild and he pretty much made me use rotella T to break it in. So I am just going by what he said.
72 Cheyenne Super
Old 11-26-2010, 12:28 AM   #22
piecesparts
My machine shop owner buddy used Rotella T on his engine break ins, until last year. He now uses a line from a small company in Oklahoma that has all of the additives and friction reducer added to it. The studies that he has done, shows him that Rotella is not what it was, so he made the change.
Frank
Old 11-26-2010, 12:46 AM   #23
Critter
Future TOTM Winner
Critter's Avatar
Everyones got opinions. For years my Dad, and now myself have run regular ol Quaker state 30wt (now 10w-30 beings straight 30 is hard to find) in South Texas. In that time my family has probably had 20 or so 350s in various vehicles and every one of them had at least 200,000 miles on them when they were sold. Not one ever burned a drop of oil or had any engine problems requiring a tear down. I am a firm believer that changing your oil regularly is more important than what you put in it (within reason, I wouldn't run the off-brand stuff that just says "Motor Oil" on it.) That being said, we run Mobil 1 synthetic in all our LS based engines. Mine is just another opinion to keep in mind...
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 11-26-2010, 01:02 AM   #24
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Originally Posted by critter View Post
....i am a firm believer that changing your oil regularly is more important that what you put in it....
x2
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 11-26-2010, 10:28 PM   #25
hayhauler71
hayhauler71's Avatar
If you are looking for a high zinc oil for a wild flat tappet cam I use valvoline vv 855 which contains 2300 ppm of zinc. Napa has it behind the counter and it,s not for street use so I know it.s good for my motor.
Fuzzy
hayhauler71 is offline   Reply With Quote
