Old 11-24-2010, 11:02 PM   #1
LS1_C10
LS1_C10's Avatar
Fuel pump went out today...
I hope.
Backed out of the driveway, made it three houses, the truck dies. Get it started again, idles fine, throw it in drive, hit the gas. It takes a minimum of 3/4 throttle to idle down the road. When you let off the gas, it dies. Also, the lights are flickering, and they have never done that before.
I drove it all day yesterday with zero problems.
Oh and its 72 degrees outside.
Oil pressure and truck temp show fine.
Has gas in it (we idled to the corner gas station...about 500 feet).
Took FOREVER to start, like 30 seconds of cranking. Never done that before either.
Help me out guys!
My 74 K1500(broken and sold)
LS1_C10 is offline   Reply With Quote
Old 11-24-2010, 11:05 PM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Fuel pump went out today...
Fuel filter, or pickup filter in the tank. That's my guess.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 11-24-2010, 11:21 PM   #3
thepenguin99
Stock pumps pretty much don't die unless you let them sit up long periods of time. I would definitely check the fuel filter or tank sock.
thepenguin99 is offline   Reply With Quote
Old 11-24-2010, 11:25 PM   #4
LS1_C10
LS1_C10's Avatar
I dont know on either of those. I think its a crate 350. Thats where my expertise ends lol. The good thing is my mechanic was here tonight, bad news is he didnt wanna fiddle with it. We did not see a fuel filter. Where are some alternate locations?
Old 11-24-2010, 11:36 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
prolly at the end of the fuel line and sorta inside the carb you have to disconnect the fuel line then the fitting behind that
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-24-2010, 11:40 PM   #6
LS1_C10
LS1_C10's Avatar
that doesnt sound like something i could mess up too bad. Maybe Ill wait till daylight tho. It died at the end of the driveway. Thanks man
Old 11-25-2010, 02:02 PM   #7
83burban
easy way to check for fuel pump operation is to disconnect the fuel line from either the carb or the throttle body and disconect that ignition wire.
If it is carbed put a water bottle over the end of the disconnected fuel line and crank it for a few seconds - should fill the water bottle fairly quickly if it is good.
If it is TBI - fuel pump is electric - all you need to do is turn the key to the on position - no need to crank - and the fuel pump should shoot fuel out (note that the electric is much higher pressure and will fill the bottle more rapdily)
If fuel pump is fine then check the filter and work your way back for either a leak or an obstruction somewhere down the line.
83burban is offline   Reply With Quote
Old 11-25-2010, 02:20 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
tbi filter on the frame rail
or follow the carb line @ in/the carb
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-08-2010, 11:08 PM   #9
LS1_C10
LS1_C10's Avatar
Alright. Slight update.
Pulled fuel line, it dumps fuel fine.
Put it back together, and the truck starts and idles fine. Let it warm up, drop it into reverse everything still sounds good. Click to drive, it sounds like its missing terribly and dies. :/
Suggestions or ideas?
Old 12-09-2010, 09:44 PM   #10
goatwrangler
Just curious but do you have an auto or manual tranny ? I'd look for a vacuum leak...Does it also die when you step on the gas in neutral?
After the vacuum, I'd check your spark plugs and spark plug wires.
Jason
1989 Crew cab 2wd 8 lug and staying that way
88M 638th ASB Lafayette, IN
goatwrangler is offline   Reply With Quote
Old 12-10-2010, 02:03 AM   #11
LS1_C10
LS1_C10's Avatar
Its an automatic. We were gonna do a carbon buildup check next week.
Old 12-17-2010, 02:55 AM   #12
LS1_C10
LS1_C10's Avatar
Welp....lol we were kind of afraid to check the spark since we had a gas leak in the neighborhood yesterday
