Old 11-30-2010, 11:13 PM   #1
PORKY
PORKY's Avatar
Help - 454 mounts, power steering, disc brakes,emergency brakes
1. I recently purchased a 1965 Chevy C10 Pick-Up. It’s a SWB. It came with a BBC 454 and a 4-speed Muncie (I think it’s a Muncie). It was originally a 6cyl. with a 3 on the tree.
The engine and tranny conversion was not done real well. The motor mounts and clutch linkage leave a lot to be desired. The rear tranny mount is ok.
I NEED,
Correct motor mount perches for the big block.
Correct motor mounts for the big block.
Correct clutch components from the pedal to the throwout arm.
2. All emergency brake mounting hardware is missing. By this I mean, the rods and connecting mounts etc. under the truck that join the 3 cables DOES ANYBODY HAVE THIS STUF??. I have the 3 cables and the handle inside is ok.
3. I want to add power steering and front power disc. brakes.
What is the best way to do this for a reasonable budget number?
I'd sure appreciate any help anybody can give me here.
THANKS
PORKY is offline   Reply With Quote
