Old 11-30-2010, 11:41 PM   #1
coggonobrien
67-72 vs 73+ axle question
just curious if there is a differance from wheel mounting surface to wheel mounting surface in width for the front and the rear.
Thanks,
David
coggonobrien is offline   Reply With Quote
Old 12-01-2010, 12:08 PM   #2
raycow
Re: 67-72 vs 73+ axle question
Well, the thing is, 67-72 aren't all the same. The rears changed in mid 70, and the later ones are the same width as 73-87. So early = 62" and late = 63-1/2". I believe the fronts changed in 71 when the disc brakes started, but I don't know the actual width.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 12-01-2010, 12:17 PM   #3
coggonobrien
i see so if i part a blazer to convert to 4x4 i would use 4.5bs wheels where as with the later trucks i would use up to 5.25?
Old 12-01-2010, 12:28 PM   #4
raycow
Sorry, but can't offer any help with the backspacing. You will need to hear from someone who is into wide tires for that.
Ray
