12-08-2010, 12:30 AM | #1 |
BMW & ASE Master Certified
New GM door to cab seal = really hard to close door :(
Obviously its becuase the seal is new, but for those who have installed new seals, about how long did it take for the gaskets to settle down and regain a normal closing door. Im not too happy with the opend box I recieved.. the gasket wasnt in a nice coil as I figured it to be in but.. anyway Its installed so no turning back now. It had a few flattened spots but Im sure it will even out. Maybe on the other side, I will lay the seal outside to get warm before putting it in the truck too?
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
12-08-2010, 01:21 AM | #2 |
Resident of Here
Re: New GM door to cab seal = really hard to close door :(
You have to slam the door. Not because the seal is new, but because the seal is tight(air tight cab), it's air pressure from the door closing. I had a K10, when I bought it the P.O. had put new seals on it 6 months before. I had it a year and the doors still had to be slammed shut.
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
12-08-2010, 08:34 AM | #3 |
Third street is right on. There's no place for all that air to go when you are slamming the door, particularly with a regular cab truck.
I normally roll the window down a bit, or keep my door open while waiting for my passenger to close their door (then slam mine). I haven't tried this, but I suspect if you take the little flapper valve out of the vents in the bottom of the door (the "PRV", or Pressure Relief Valve) it might allow a bit more airflow and help the situation. The tradeoff is that you might get a little more cold air creeping in during the winter months. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
