62 master question
Has anyone mesured the travel on a stock 62 master manual set up?? Bore size is 1 1/8 however I am having some issues with my hyd master for the clutch ( longer story there
![]() Join Date: Oct 2006
Re: 62 master question
Are you swaping it to a dual master and seprate clutch master or just replacing the stock one?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
have a hyrdo boost and using a wildwood master.. I just need travel on stock master/ hydo clutch master..
oh ok .........
Measure the travel of your clutch pedal from the top stop to the floor at the pushrod pivot point
62 GMC 910 short fleetside 454 super t10 14 bolt w/gov lock 70s c20 front discs (built in the 80s) 65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck) 63 GMC 950 camperized school bus, (Gus the bus) 350 4speed 2 speed rear 64 GMC 950 "spare" bus 283? 4speed detroit locker 53 GMC 1ton dual wheel bus 78 GMC c25 short course off road race truck(son's truck) 355 th400 14 bolt (www.wheel2wheel.ca) 88 Peterbilt 379 longhood (hauls race truck) ![]() ![]() ![]() ![]() |
I went the other route and did the volume way all good .
Good news, so how is the clutch master working for you?
Well at this point I may end up making a new booster plate kit and having to relocate the clutch master... Will see what happens.
