rotors?spindles
Hey looking for some help I have a 62C10 that I swapped front c-member from a 78. I bought a set of dropped spindles for the 78 clip from a forum member, does somebody make 6 lug rotors for these spindles? Also theres no name on the spindles. I have aftermarket 6 lug smoothies so I dont want to go 5 lug
Re: rotors?spindles
Check w/some of the board vendors for the 6-lug 'swap' rotors (more than one has them).
Re: rotors?spindles
So Im bagging my truck i had the disc brake kit on the 62 with drop spindles do i really need drop spindles if im baggin it? what will be effected with running the stock spindles the reason i ask is my rotors fit the stock 78 spindles but not the lowered spindles the hubs are different sizes.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: rotors?spindles
I bet your drop spindles are for the Light Duty 1" wide rotors.
All aftermarket 6-lug rotors are the 1-1/4" wide version. Posted via Mobile Device
Re: rotors?spindles
ECE or Performance On Line sells the 6-lug rotors.
Re: rotors?spindles
so heres where im at with this. my rotors fit fine on the stock spindles so if i use them what am i losing the obvious is 2" drop at ride height but if I'm bagged what"s the difference?
Re: rotors?spindles
Ride quality. The bag needs a certain height/pressure to achieve good (proper) ride quality. If you want the ride height @ a certain level, it may or may-not be optimum. Dropped spindles are a quick/easy way for making that adjustment w/o detrimental impact.
Re: rotors?spindles
x2
Re: rotors?spindles
I would like to know if the 92 3/4 ton 2wd rotors have 5/8s studs and how long is the bearing race . I have a set of newer 6 lug 5/8s studed 20'sthat have 3 inches of space from cap to lugs
