Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 12-18-2010, 05:59 PM   #1
TagMan
Wiring a '63 2-speed wiper switch
I found a 2-speed wiper switch with a push button for windshield solvent spray. The switch has three wires: Black, light blue & dark blue. I looked in my '63 shop manual, but the only wiring diagrams are for single speed switches. This is a new installation, so there are no old wires to follow. Can anyone tell me which wire goes where?
Thanks,
-Bob
TagMan is offline   Reply With Quote
Old 12-21-2010, 11:37 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: Wiring a '63 2-speed wiper switch
My truck has this option and I'll try to get the info this weekend as I'm cleaning up some wiring stuff.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-23-2010, 05:29 PM   #3
TagMan
Thanks, protrash64. I'll watch for your reply.
Thanks and Merry Christmas!
-Bob
Old 12-23-2010, 05:50 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Perhaps this will help:
http://www.persh.org/Pickup/Wiper-washer.htm
Old 12-23-2010, 11:04 PM   #5
protrash64
protrash64's Avatar
Cool link, Mark. My switch doesnt work properly. Wipers only turn on when the fluid button is pushed; sounds like it may be a grounding issue from the description.
Old 12-26-2010, 08:34 PM   #6
TagMan
Originally Posted by markeb01 View Post
That's exactly what I was looking for - thanks a million for helping me out!
-Bob
Old 03-30-2012, 12:20 AM   #7
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Did a search and this thread came up.
I've tried using the diagram in the above thread. Persh link Does everything have to be hooked up such as the pump? I'm not gonna run a pump.
I'm not getting anything. I bench checked the motor and it checked good I think. I got two speeds and park. I don't know how I did it cause I didn't have a good switch. I just unhooked wires until I got 2 speeds and park. Now the motor is in and I have a good (new) switch.
Here's my motor
Alan's Classic is offline   Reply With Quote
Old 03-30-2012, 07:28 PM   #8
Alan's Classic
bump for previous question.
I don't know if the wiper motor is a factory replacement, I think not.
help appreciated.
Old 03-31-2012, 10:29 PM   #9
ray_mcavoy
Hi Alan,
No, you don't need the washer pump hooked up to make the motor work.
The black w/yellow wire is a +12V feed that's live whenever the ignition switch is on.
For low speed, the switch grounds both the black and black w/blue wires.
For high speed, the switch only grounds the black w/blue wire.
Check to make sure your switch is making good electrical contact where it mounts to the dash. If the dash has been repainted it might be keeping the switch from making good contact.
ray_mcavoy is offline   Reply With Quote
Old 03-31-2012, 11:16 PM   #10
Alan's Classic
Originally Posted by ray_mcavoy View Post
Hi Alan,
Thanks for the help. You might have discovered my problem. I've got the switch out laying in the floor to aid in testing. I guess I need to ground the switch body. Why didn't I think of that.
Old 04-01-2012, 12:28 AM   #11
Alan's Classic
Your the man!! I grounded the switch and what do you know it worked. Thanks again.
Old 04-01-2012, 12:37 AM   #12
ray_mcavoy
You're welcome!
Glad to hear it was a simple fix
Old 03-24-2013, 09:39 PM   #13
1963c-10
1963c-10's Avatar
im doing the same conversion. my donar motor and pump came from a 63 c10, but my wire colors are different.-
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-25-2013, 10:54 AM   #14
1963c-10
1963c-10's Avatar
Heres a few pics of my two speed wiper w/washer. Shows part # 5045342 Type E 12V delco appliances date code Jan 63
