Old 12-20-2010, 12:51 AM   #1
jakeblues652
jakeblues652's Avatar
gear ratio ?
so ive had my 67 for a couple of weeks now, and you can't get that thing over 60. when i say you can't, the needle wont go a touch over. its a 4 speed. any way of getting the gar ratio without going into the housing? i was at the parts store today..15 bucks a quart for synthetic gear oil. also, the previous owner told me it was posi if that helps.
1967 K-10 4x4 with a 3" lift and 35" BFG mud terrains
Originally Posted by Dan in Pasadena View Post
Did you figure out how to fix it?...I mean with other than a BFH?!
want to see some slow progress on my truck? http://67-72chevytrucks.com/vboard/s...d.php?t=436560 <-click there
jakeblues652 is offline   Reply With Quote
Old 12-20-2010, 01:46 AM   #2
bfay17
Young Gun
bfay17's Avatar
Re: gear ratio ?
If it were mine i would spring for the gear lube and pull a cover just to check everything out and count some teeth. (Did this in my 70 and found 4.56's) May cost a little bit but then you know exactly what you have and the shape its in Just a little peace of mind
bfay17 is offline   Reply With Quote
Old 12-20-2010, 02:06 AM   #3
jakeblues652
Re: gear ratio ?
thanks for the advice. the problem is if i do it in the back, i want to do the front too (4 wheel drive gets used a lot around here) and you figure 2-3 qt per case and you got 90 bucks each, so 180 just for gear oil, before the gaskets. a little pricey if you ask me.
Old 12-20-2010, 09:31 AM   #4
donut
donut's Avatar
Re: gear ratio ?
Jack up the rear (neutral). put a mark on driveshaft and one on a wheel. rotate the wheel once and count how many times the driveshaft turns. iirc this should give you the ratio.
driveshaft just a tic over 4 turns, 4.10. 41/2 turns 4.56. This is going off memory, personally I haven't done it in a few years. Ideally, you'd count teeth.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 12-20-2010, 11:27 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: gear ratio ?
$15 is too much for a quart of synthetic gear oil -- look for a different brand, check at other stores, or just go with dino. Probably worth changing since you recently got the truck and don't know when it was last changed.
As to gear ratio, this is the method I use -- I'll quote board member raycow from a previous thread.:
Re: How do you calculate your gear ratio?
You don't have to take off the cover unless you really enjoy draining the oil, getting yourself greasy, scraping off the old gasket, etc.
Put matching marks on the pinion yoke and differential housing. Jack ONE rear wheel off the ground, put the transmission in neutral, and the parking brake off. Turn the wheel exactly TWO revolutions and count how many times the driveshaft turns, estimating any fractional turn as closely as possible. That number is your axle ratio.
If the wheel is difficult or impossible to turn, you may have posi. In that case, jack both rear wheels off the ground and turn either of them only ONE revolution. Count the driveshaft turns the same way as for an open rear.
Ray
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-20-2010, 01:28 PM   #6
bfay17
Young Gun
bfay17's Avatar
Re: gear ratio ?
Not trying to be a A$$ here but your looking at 6 quarts of lube which at 15 a quart would be 90 for the front and rear axle. I was always taught to just use black rtv for the gasket. I'm not saying that my way is golden or that you shouldn't use the gasket I'm merely saying what i was taught. Even with gaskets you shouldn't be much over 100 for it all i wouldn't think. Like Stocker said though 15 a quart is crazy even for synthetic. Not trying to start a fight here either so If i offended you I'm sorry and i will delete my post.
Old 12-20-2010, 04:48 PM   #7
jakeblues652
Re: gear ratio ?
yeah, i just thought 90 bucks was a little crazy...and i was always told to never reuse the gaskets, and use gasket sealer sparingly on them just for the best seal. but it changes from person to person i guess. and this truck, i want to cut as few corners as possible.
Old 12-20-2010, 04:50 PM   #8
Redcap
Re: gear ratio ?
Use RTV instead of gaskets and get a decent quality dino oil.
Redcap is offline   Reply With Quote
Old 12-20-2010, 05:05 PM   #9
bfay17
Young Gun
bfay17's Avatar
Re: gear ratio ?
I completely understand not wanting to cut corners. If you use the black rtv you dont even need a gasket it will set it up very nicely. I just use a 1/4 to 3/16 thick bead around the whole cover and i havent had one leak yet. Again im not saying its the only way to do it.
Old 12-20-2010, 06:06 PM   #10
jakeblues652
Re: gear ratio ?
well, its posi. found that out today. and also did a little test. 10 miles per hour maybe 13 if you really rev the pi** out of it. thats in second.so im thinking either 4:10's or 4:56's. either ratio, im happy.
Old 12-20-2010, 09:16 PM   #11
Mike C
Mike C's Avatar
Re: gear ratio ?
Are you saying your motor is done at 60 mph? And you have 35" tires? With 4.10 gears in my Jimmy and 36" Wrangler RTII (exact same height as the 35" BFG's I took off) I do 2500 rpm at 60 mph. Do you have it stuck in low range or something? That would seem likely with 5000 rpm at 60.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-20-2010, 10:00 PM   #12
jakeblues652
Re: gear ratio ?
the speedo reads 60, which is closer to 65 with the tires. its about 5 mph slow with the mechanical speedo. and i bet its at 3200-3500, but thats the top end for me at highway speeds. i dont like cranking out that many revs with an old motor.
Old 12-27-2010, 02:34 PM   #13
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: gear ratio ?
Gee with stock tires at 60 mph im EASILY running 3k + lol This is on a C10 (2wd) I just discoverd this board so I thought id post
John
1999 Toyota Tacoma 4x4
Old 12-27-2010, 04:44 PM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: gear ratio ?
- Mike -
RIP El Jay
Old 12-27-2010, 07:15 PM   #15
jakeblues652
Re: gear ratio ?
do you know your ratio, cause that sounds like my truck, but luckily i have 35's
