Old 12-22-2010, 09:47 PM   #1
Chips-resto
big block swap
any help on putting my big block in my 86 3+3 4x4. I'm having a brain fart on the motor mounts. I have another one ton with big block motor mounts in it but it's not a 4x4 n the cross member is not the same. Maybe I'm overthinking this but I'm at a loss. Its better to ask and feel stupid rather than wastse tons of time n still have to ask
Chips-resto is offline   Reply With Quote
Old 12-22-2010, 10:00 PM   #2
Chips-resto
Re: big block swap
Ok,lets try this. anyone know if I need to move the pads or just drop it in?
Old 12-22-2010, 10:19 PM   #3
cor86
Re: big block swap
Just drop it in.
cor86 is offline   Reply With Quote
Old 12-22-2010, 10:36 PM   #4
Chips-resto
Re: big block swap
So the pads are in the same spot from small block to big block/ if so thanks. I had to put small block in her years ago and just now got another big lock done to put in her.
Old 12-22-2010, 10:45 PM   #5
cor86
Re: big block swap
The only thing different between the SBC and BBC is the mount part that bolts to the block, with the BBC being shorter, I think. The bushing, or rubber/metal part, is the same. My BBC came out of a 4wd and it had plates sandwiched between the mount and block that were 4WD specific. Not really sure what they attached to, since I didn't pull the motor, but it looks like they connected braces from the motor to the frame?
And yes, the pad location is the same, as far as distance from the firewall goes.
Old 12-22-2010, 10:49 PM   #6
b454rat
Re: big block swap
I've always heard those as clamshells, and they are the same between small block and big block. Car and trucks are different. Doesn't matter 2wd or 4wd, SBC or BBC.
I did many SB to BB swaps, never changed the rubber mounts.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 12-22-2010, 11:17 PM   #7
Chips-resto
Re: big block swap
Thanks. I remember now. I have the plates on the small block still. They Have the rods that run down to the inspection cover. On the 4x4 its a heavy aluminum cover and they're suppose to help stiffen the th400 up . Hopefully I can hear her run tommorow. Thanks again
Old 12-23-2010, 02:32 AM   #8
bmchevy1979
bmchevy1979's Avatar
Re: big block swap
just a fact but those are also used on the th350 4x4 trans
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 12-30-2010, 10:44 PM   #9
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Re: big block swap
Check my signature for the link to my swap.. went in and fits like a glove. Mounts were the same.
Ken
87Lowrider is offline   Reply With Quote
