Q jet choke problem
Ok, I've been here before with this problem, with no luck fixing it yet. 72 K20 Does not want to stay running right after a cold start. The choke closes fine but vaccume pulls it open as soon as it starts. The spring tstat is fairly new, I have tried to bend the choke linkage to adjust the travel but the vaccume piston is overriding everything. I kind of need to fix it because I use the truck for snowplowing. Thanks
Re: Q jet choke problem
Have you got a pic of your choke. You might need to lengthen your choke pulloff linkage rod.
I have tried to adjust many things on that card but never that. Many thanks. It works great now. I never knew that rod could be bent to make it longer.
laying low
![]() Join Date: Mar 2001
Fine tune the qjet and they really are great carbs.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
I guess I gotta find a good shop book on this carb. My old Chiltons book wasnt helpfull on this thing.
Here's a link for you.
http://www.vetteprojects.com/kstyer/quadrajet.htm And look on amazon.com I think they list a book on how to rebuild the quadrajet. ![]() Last edited by geezer#99; 12-26-2010 at 04:43 PM. |
Champagne Taste on Beer Budget
Good info!
Trying to add an electric to my Q-Jet as it just has the choke and arm but nothing really attached to it.
Coming Soon: Project 1970 Country Truck |
