Old 01-04-2011, 01:57 PM   #1
ldgn63
Another BRAKE HOSE question…
Installing disc/2.5 drop on a ’67 using western spindles.
I have an old junk drivers side hose off a donor truck for test fit but I cant seem to make it fit from front (like later models) or the rear (like the orig routing). The steel part of the hose has a factory bend just before the banjo flange and the caliper has what appears to be a channel (or hose groove) that clocks the brake hose so that it only mounts from the top.
So the question…
Are you guys using factory late model (73-87) truck hoses with the bend or a hose from a car that doesn’t have the bend? It looks like the car ones might work if I keep the orig routing…
(when will I learn to just buy the “kit” so I don’t have to chase everything down?) lol
ldgn63 is offline   Reply With Quote
Old 01-04-2011, 02:07 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Another BRAKE HOSE question…
ECE (www.earlyclassic.com) sells a "conversion" hose that connects in the stock 67-70 location, (behind the crossmember), and is long enough to reach your new caliper.
Keith
Convert to disc brakes.
Old 01-04-2011, 02:16 PM   #3
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
I bought stainless steel lines from here. Sent them my stock rubber hose and the came back perfect.
http://www.bonacoinc.com/
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 01-04-2011, 02:39 PM   #4
ldgn63
thanks guys.
im hoping for an OTC solution...
it seems like someone mentioned Chevette hoses but i cant find the post now.
i just went outside and peeked at a 80-ish suburban for ref but the caliper inlets look like they are located different than the truck to me.... i woulda thought them the same.
i have to drive 45 minutes to work on the truck and i hate showing up with the wrong parts! lol
maybe i'll buy truck and car replacements and bring one set back....
