Where to find a spid sheet?
I just bought a 88 crew cab and there is no spid in the glovebox. The truck is untouched on the interior, so I was wondering where to look for a spid in the interior. Is there one tucked under or inside a seat?
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
Re: Where to find a spid sheet?
under the rear seat in the springs...
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great 1979 Chevy 1/2 ton long bed diesel 1974 Chevy crew cab short bed 3/4 ton 4x4 project 1991 Chevy suburban 2wd 1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo 1961 Chevy pickup 1/2 ton 2wd 1975 gmc crew cab short bed 2wd |
The SPID should be in the glovebox. That's a build requirement, so it had to be there before the vehicle left the plant. They do sometimes come unstuck (mine did) and fall under the seat, mats or wedged in the carpet. You might check there.
The "build sheet" is what is sometimes gets placed in the seat cushions. It's a different document (different format and purpose that the SPID) and it was not a requirement for it to be placed in the seat. Depends on the build plant, build shift and individual operator. It was sometimes just easier to build the seat up around it than it was to pull it out and throw it away. Having said that, it can't hurt anything to pull the seat up and see if anything is there (mine wasn't ).K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 01-08-2011 at 04:25 PM. |
Thanks for the info guys.
What does spid stand for??
"Service Parts Identification" label.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
| Bookmarks |
