Old 01-08-2011, 09:00 PM   #1
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Do I need to hot tank my block???
Hi there,
against my better judgement I used walnut shell to blast & clean off the rust off my engine block....but some / lots of walnut specs got into the valley and on the crank.
Am I stuck with having to hot tank my block or is there a solution / oil I can run through it to take out the specs?
Thanks!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 01-08-2011, 11:52 PM   #2
mongoose
mongoose's Avatar
Re: Do I need to hot tank my block???
wipe what you can up... spray the rest off with some brake cleaner.. clean out the oil pan run some fresh oil and change the oil filter after a while of running..
what i would do... unless i want to rebuild it... no sense taking it all apart without rebuilding the thing.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 01-09-2011, 12:55 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
im going to move this to engines for more better responses
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-09-2011, 12:59 PM   #4
chevybuldr
chevybuldr's Avatar
Whats the worse that can happpen? ruin it? You can always rebuild it after it has problems in stead of re-ringing it now. That kinda how we look at it.
chevybuldr is offline   Reply With Quote
Old 01-09-2011, 01:01 PM   #5
cableguy0
You better just start taking it apart. You will never get it all out by hand. Remember if its rough enough to knock rust off its going to destroy the bearings. You need to tear the engine completely down. Pull the heads cam/lifters and crank rods and pistons. Those pieces are small enough they can and will make it past the oil pump screeen. IN the end its up to you. But if you dont tear it down I would start setting large amounts of spare cash aside for the rebuild thats coming.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 01-09-2011, 02:46 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Yep... no way I'd even attempt to clean that out and use it without a complete teardown. Chock it up to a lesson learned...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 01-09-2011, 02:50 PM   #7
allengator
allengator's Avatar
Yup... It's all gotta come out!
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 01-09-2011, 02:56 PM   #8
BigRed76
BigRed76's Avatar
Gary
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 01-09-2011, 03:42 PM   #9
Ticker
It's organic, which is one of the benefits of using walnut shells...but it's all got to come apart at this point as that stuff is going to block an oil passage or get into a bearing and that's it.
Ticker is offline   Reply With Quote
Old 01-10-2011, 02:15 PM   #10
Gordonr1973
Home Built '87
Thanks for the input....it's booked in to get hot tanked and a slight rebuild!!
Gordon
