Old 01-13-2011, 07:03 AM   #1
D-Day
Live fast, die young
D-Day's Avatar
Pegged heat gauge - faulty gauge or thermostat?
So, I left my truck sitting for a couple weeks being only driven by my girlfriend's dad to work once, and since getting back I took it for a drive tonight, and on the way back I noticed the heat gauge near and in the red. It would randomly drop below the red just by a hair on occasion. It has never, ever done this that I can remember. At most it would go halfway right before the thermostat "popped" and let the coolant flow through and the temp would drop back to normal.
After letting it sit a few minutes, I released some pressure with the radiator cap lever, and started it again. It was instantly back down to halfway, though I could see it creeping slightly again. It hadn't cooled down enough to check the coolant level without it bursting open, so I'm letting it thoroughly cool down. This is right before I'm supposed to leave for home, a 376 mile trip.
One thing I noticed is when I shut it off the second time testing it, the gauge would peg all the way to the right, and I mean all the way (well past red) - like when you have a twitchy ground and the gauges don't work. I can't tell if it's telling me the right thing. I could hear a lot of noises when I shut it off in the hoses/radiator from heat/boiling/pressure that I don't remember normally hearing, so who knows.
My heater was also putting out lukewarm air and not doing a very good job, lesser than normal.
The first obvious things I'm going to check are the coolant level, I'm hoping maybe it's just something dumb like that. I would have checked that before posting this, but I don't have luck that good and figured it'd be helpful to have this thread already started. If it's not that, well...I think my only other immediate and cheap option is to check/replace the thermostat.
One last note...I heard a squeak from something at two different times, like a belt slipping. That's not very common with my truck either...sometimes when it's cool and damp you get it at idle before the belts are warmed up, but never under load. Perhaps a slipping belt or bad fan clutch too...?
I don't know. It's around 15-20 degrees here in the hills of Kentucky, and even though the hills provide a good engine workout, it wasn't pushed that hard since it was snowing and I went slow most of the time. I wouldn't think a mere fan would cause that drastic of an overheat unless something else was wonky too.
Forgot to add it's a 400 engine. Anyone have experiences with this? Please tell me it's something simple and not a $300 water pump or ungodly head gasket or whatever else is out of my budget right now...
Much appreciated guys.
D-Day is offline   Reply With Quote
Old 01-13-2011, 07:38 AM   #2
splehigh
splehigh's Avatar
Re: Pegged heat gauge - faulty gauge or thermostat?
I think I would try the thermostat first. You could remove the thermostat completely and see if the engine stays cool that way.
splehigh is offline   Reply With Quote
Old 01-13-2011, 09:37 AM   #3
silvereagle07
silvereagle07's Avatar
It sounds like your truck is overheating. The 400 I had did not have water jackets between cylinders and insufficient cooling. You could try a thermostat but be sure to bleed all the air out of the system. Good luck.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 01-13-2011, 09:44 AM   #4
monza1979
monza1979's Avatar
Is your block frozen? i see you said it is 15-20 over there. im only askin because i've made the same mistake, not enough antifreeze.
I had the right to remain silent, but i didn't have the ability!
78 chevy swb 4x4 sm465 np205 350 4" lift, ORD flip kit, ORD Ext. brake lines
79 Chevy Monza:current plans, dz 302, 4 speed
69 Pontiac Firebird: 74 s.d. 455 build up, m22 rock crusher
monza1979 is offline   Reply With Quote
Old 01-13-2011, 12:00 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
thinkin the same thing use a tester to check if it's enough
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-13-2011, 08:08 PM   #6
ironroad9c1
Master Hater
DO NOT remove the thermostat completely, the water will not stay in the radiator long enough to cool off Just buy a new 195 t stat and be done, Also side up under the front of the engine and see if the water pump is seeping out of the weep hole. could be dripping on the belts while it sits and Antifreeze and belts don't mix.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42
"This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors
ironroad9c1 is offline   Reply With Quote
Old 01-13-2011, 08:32 PM   #7
S10Fan
Old Heap Driver
Agree 100%!
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 01-14-2011, 07:02 PM   #8
D-Day
D-Day's Avatar
Luckily it was just low coolant, and made it home. Gotta replace the water neck gasket 'cause it's leaking like a sieve.
Old 01-14-2011, 07:43 PM   #9
silvereagle07
Cool deal! At least you found it. I would replace the thermostat and gasket while I was there.
Jeramy
'85 Chevy 4X4 SOLD
