Old 01-13-2011, 09:50 PM   #1
3r!c84
Badass
3r!c84's Avatar
lots of play..
ive got alot of play in my steering wheel. it feels like more in the steering box then anything. checked tie rods. inner and outter. all fine. and pitman and iddler arm are fine. its just the box has alot of play.
how much is a new box?
is it hard to replace?
any other boxes that are a "upgrade"
thanks, Eric
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-13-2011, 11:36 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: lots of play..
Eric,
Check my post in this thread; http://67-72chevytrucks.com/vboard/s...d.php?t=440370.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-13-2011, 11:45 PM   #3
Gregs71
Re: lots of play..
To give you an idea. I think I paid close to $500 for a new steering box installed by Big O tires. Not sure if make model matter but that was for a 1-ton 4x4 dually
1995 GMC 4x4 1/2 ton
1999 Jeep Wrangler w/ 33's
68 camaro 350/350
1987 Chevy 3/4 ton 4x4
Suzuki DRZ 400s Dual Sport
1971 chevy long bed 2x4
194? Dodge 2.5 ton
1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455
1989 Chevy V30 crewcab dually 454/TH400
Gregs71 is offline   Reply With Quote
Old 01-14-2011, 02:36 PM   #4
Your41Plague12
Your41Plague12's Avatar
Re: lots of play..
Check where the steering box is bolted to the frame. If your box leaks any fluid at all, the fluid could help the bolts loosen up over time. I just fixed this problem on mine, 1000% improvement.
Your41Plague12 is offline   Reply With Quote
Old 01-14-2011, 03:38 PM   #5
3r!c84
Badass
3r!c84's Avatar
Re: lots of play..
just replaced the high pressure line. no leaks now. but still very lose. ill try tighting that nut? see if it will help
-00 Saturn 5spd
1/4:13:90
Old 01-14-2011, 04:46 PM   #6
Rons86
Rons86's Avatar
Re: lots of play..
If the bolts to the frame are not loose you can try tightening the gears by loosening the nut on top and tightening down the allen wrench bolt in the center. Usually this is a stop gap at best and the best thing is to replace the steering box.
Rons86 is offline   Reply With Quote
Old 01-14-2011, 05:25 PM   #7
pseudopimp
pseudopimp's Avatar
Re: lots of play..
i got mine at autozone pretty straight forward replacement. only $145 after you give them the core.
84 Scottsdale LWB K10
Rooting against the cowboys is almost as fun as rooting for the GIANTS!
pseudopimp is offline   Reply With Quote
Old 01-15-2011, 01:58 PM   #8
3r!c84
Badass
3r!c84's Avatar
Re: lots of play..
Can it be loose and worn out inside and still not leak? Mine is not leaking. Idk if or when it was replaced last. It still looks good.. Just loose
-00 Saturn 5spd
1/4:13:90
Old 01-15-2011, 05:52 PM   #9
SS Delux
SS Delux's Avatar
Re: lots of play..
can you adjust the screw on top of the box the same for a mannual box as you would a power one ?
SS Delux is offline   Reply With Quote
Old 01-15-2011, 10:38 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: lots of play..
Yes
