Old 01-19-2011, 12:01 AM   #1
CrazyJesster
CrazyJesster's Avatar
windshield from 70 to 82
so would a windshield from a 79 fit an 82?
only issue is that my 82 has the built in antenna
sorry typo in heading this is 79 from 82
Project 82 ReBoRn http://67-72chevytrucks.com/vboard/s...d.php?t=441842
CrazyJesster is offline   Reply With Quote
Old 01-19-2011, 12:27 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: windshield from 70 to 82
All years 73-87 are interchangeble. Yes, the antenna option was not available on some older models. You can install an aftermarket antenna. Installers recommend a new rubber seal for windshield replacement.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 01-19-2011, 12:30 AM   #3
CrazyJesster
yeah i kinda figured the new rubber part and im thinkin a free windshield is cool
did the internal intennas realy work all that good or what?
Old 01-19-2011, 12:34 AM   #4
gchemist
gchemist's Avatar
Nope, mine can't pick up stations over 25 miles. I live in the city too.
Old 01-19-2011, 12:40 AM   #5
CrazyJesster
well guess that solves that then ill have to do some research. on where i can mount an antenna when its time for that. i mainy listen to cds anyway so may just deck the 82 out with a nice stero system. cd and ipod stuff
but thanks for the info on the windshield now i can use this replacement. mine windshield is gone cracked badly.
Old 01-19-2011, 12:45 AM   #6
bmchevy1979
bmchevy1979's Avatar
might be yours because you can't touch mine I live outside of town near our power plant and in the morning and afternoon I have to drive under those BIG power lines radio still clear as ever
<Brandon>
1974 Chevrolet K5 Blazer 350sbc/SM465/NP205, dana44 front, corp 14bolt rear with 4.10s and a powertrax locker, custom rear bumper 400sbc in the works.
1981 GMC C1500 stepside 250i6, 3spd, 12bolt with 3.08s 2.5/4drop on 15x10 with 275/50r15
81 GMC C3500 cab-chassis dually with utility bed 350sbc, Sm465, 14bolt with 4.10s nv4500 getting ready to go in
1979 Chevrolet K5 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434096
1976 Chevrolet C10 R.I.P. http://67-72chevytrucks.com/vboard/s...d.php?t=434195
bmchevy1979 is offline   Reply With Quote
Old 01-19-2011, 12:46 AM   #7
BigRed76
BigRed76's Avatar
My 76 has the built in antenna and it works great! Also have an aftermarket stereo so idk if that helps any.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 01-19-2011, 12:50 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
I've used the "in glass" one no probs
maybe check your ant plug there are diff sizes might not be in all the way
and the snap is on at the bottom
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-19-2011, 12:50 AM   #9
CrazyJesster
well its a free windshield and i say free is cool. plus it will allow me once the ride is running to get it inspected an all. i really dont want to do away with built in antenna but . i really dont have much choice right now
Old 01-19-2011, 12:51 AM   #10
bmchevy1979
bigred76 I don't think it does because mine worked great with the factory radio as well
<Brandon>
Old 01-19-2011, 01:00 AM   #11
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Mine has an "in glass" antenna to.....I can't tell you if it works or not because the stereo is a piece of crap...every time I hit a bump it cuts out....and I have to slap the dash again to make it come on....I don't know if it's just mine or does anyone else who uses the "in glass" antenna have a small rectangular piece of plastic where the antenna wires come out of the glass? Mine has that small piece of plastic there at the base and it's filthy and I don't know if I should cut it off or not cause I don't know if it will mess up the antennae
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 01-19-2011, 10:43 PM   #12
raws67
raws67's Avatar
My 84 has the windshield antenna and it works great. I put a new windshield in about a year ago and I can tell you be carefull installing an old piece of glass with a new seal. I went through two used pieces of glass before I had to accept the fact that they were too brittle and the new rubber can be a b*^ch to install. If you can save the rubber then I would suggest that. Also make sure you do it when its warm as possible. Good luck. Ohh and that ant. connection is just a snap on and its possible that you could have one thats loose other than that you cant beat an in glass ant in my opinion.
raws67 is offline   Reply With Quote
Old 01-19-2011, 11:00 PM   #13
Pop's C-10
Pop's C-10's Avatar
Amazon.com: Hidden Antenna - Fits Car, Truck,... Amazon.com: Hidden Antenna - Fits Car, Truck,...
Pop's C-10 is offline   Reply With Quote
Old 01-19-2011, 11:13 PM   #14
83burban
I have an in glass antenna coupled to a mirror mount one that I put on when I attached my CB antenna. The two wires go into a splitter with then feeds into the radio.
Crystal clear and GREAT reception in both city, hwy, country and under power lines.
83burban is offline   Reply With Quote
Old 01-20-2011, 01:55 AM   #15
Your41Plague12
Your41Plague12's Avatar
I've never had any problems at all with my in-windshield antenna. My radio is loud and clear using it. I'd just mount the new antenna to the passenger side fender near the windshield, it should look nice and normal.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
