#1 | |
Conversion Truck Addicted
Duallys on 17-19" wheels
im thinking about getting some alloy wheels for mine but i dont like the low profile i want some sidewall but i also think the stock 16" is too small and theres too much sidewall action
![]() Pics!!!
Thomas Quote:
Re: Duallys on 17-19" wheels
I've been looking for interchangability on wheels myself.
The new model GM & Dodge dually trucks have 17" steelies from the factory. I have a buddy w/a yard that says he can get the newer wheels if I want to trade my current 16" Alcolas. I just haven't found much info on what it would take to swap them.... Nothing? Hubcentric adapters? I just don't like wheels that have to be polished & I'm not interested in 22's. I wish they did 20" dually wheels.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-23-2011 at 09:39 PM. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Scot,
I'd like a set of 16" Alcoas for my truck. Keep me in mind.
Will do. Any ideas on what it might take to get the newer 17" steel wheels to fit? Most google info is about swapping 19.5's or 22.5's (or larger).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-23-2011 at 09:44 PM. |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
![]() Join Date: Jan 2007
I bolted a set of late model 17" Dodge dually wheels up to my 72 C30 with no issues. 9/16 studs fit perfect and the nuts with the flat flange hold'em on.
Good to hear. The Dodge 17" wheels seem to be an easier score when searching for dually steelies.
GoatLube Experss
![]() Join Date: Oct 2009
if your not gonna lower it, go with the 22.5's and a standard tire, a heavy truck tire on a dually would last longer than the truck will and would look cool too !
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#9 | |
C35 Crew Dually
as i was interested in the new 5 star rims on the new duallys. Some dodge rims will fit years (i'm not sure) go on Dually Sene and P/M Trevor from Tennese wheel and tire. here is his site:http://www.tnwheelandtire.com/
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
#10 | |
#11 | |
GoatLube Experss
yes, they are much taller. he has made mention of lift'n or mabey convert'n to 4X4. just try'n to push him along sence I cant talk him to lower'n it.
#13 | |
I have also been doing some research on tire options. I plan to go with a 19" (19.5 milled down) but also don't want a 26.71 tire height. What I have found is that I think I am going to go with a 245/55-19 which will give me a 29.61 tire height. I can then run a 235/75-16 tire on the inside rear. If I go with this combo I will be turning 3500rpm @ 75mph with a 4.10. This is only 200 rpm's more than my stock tire height. If I choose to change my gears to 3.53 then I would be looking at 3000rpm at the same speed. ![]() ![]() ![]() Posted via Mobile Device
-------------------------------------------------------- 1984 CC Dually - 454 - TH400 - Western Hauler Edition Big plans are coming! My build thread HERE |
#14 |
I know this is an old thread, Do you have any pictures?, currently looking to do this on my 72 C-30 and have a good deal on a set of ram 17" dually wheels. I heard the hub size is too big for the 72, thanks
#15 |
He hasn't been on here since 2016 so you probably won't get a reply.
#16 |
Had a feeling, but you never know. Maybe someone else has done this swap
| Bookmarks |
