02-08-2011, 04:31 AM | #1 |
langdon Header question
Guys have any recent feedback on these? Anyone got them coated from them? Can you run these with stock intake? If so what do you do to block off the bottom of the intake where the stock exhaust bolts up to? SOrry if thats confusing..lol thanks in advance.
Im getting excited my motor will will be done in any day.. now Im looking for goodies
66 Gmc 1 ton. Long Step 351e V6 69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil 61 Shortbed Fleetside 1/2 ton.. in progress Next a 50-53! MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=447926 Last edited by BadaSs_Cal; 02-08-2011 at 04:31 AM. |
02-08-2011, 09:58 AM | #2 |
Re: langdon Header question
Mine are stock cast iron but not coated. Had the stock intake on for awhile then swapped to an Offy intake. You can run the stock intake or Offy intake without any heat added to it with a heat plate. I ran mine open for awhile. I use a heat plate sold by Langdon's cause of my cold climate. Here's some pics of my set up.
02-08-2011, 04:05 PM | #3 |
thanks man those pics help me out alot.. where do you have that right hose connected to from the heat plate? Im in central ca and we have a few 30 degree days... I might not need the heat because Im sticking with the 1 bbl.. what do you guys think, should I be ok with the plate and no heat?
66 Gmc 1 ton. Long Step 351e V6 69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil 61 Shortbed Fleetside 1/2 ton.. in progress Next a 50-53! MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=447926 |
02-08-2011, 05:34 PM | #4 |
Will those headers clear the Z bar for a manual?
Geezer, Do you have a cleaner picture of your bellcrank throttle setup? I'm trying to get a TBI setup working and would like a cleaner solution. Thanks! Last edited by Zeke's Garage; 02-08-2011 at 05:36 PM. |
02-08-2011, 06:06 PM | #5 | |
02-08-2011, 06:13 PM | #6 |
Some pics for Zeke. Sorry to highjack a bit.
And one pic for the op. Shows my stock intake with no heat plate. |
02-08-2011, 07:50 PM | #7 |
Thanks for the help bud!
02-10-2011, 12:02 PM | #8 |
That's just what I was looking for.
Thanks! |
