![]() Join Date: Dec 2008
1970 C-10 2WD shortwheel base frame (complete)
It's 6 lug and has a 3.08 running gear. This is the frame from my donor truck. It's straight with NO ROT at all. Just has typically surface rust. Sand blast it and epoxy prime it like I did to my 4x4 frame and this thing will be better then what the factory produced. Even better, here are the option codes from the glove box sticker:
F-60 Heavy Duty Front Springs G-50 Heavy Duty Rear Springs N-40 Power Steering F-59 Front Stabilizer The wheels DO NOT go with it so you will need to bring 6 lug rims with you or we can load it onto your trailer and I'll remove my rims and we'll have to strap it down on wood blocks. I am located in Milford, CT 06460 right off I-95 or Route 15 (Merritt Pkwy). You won't find many in this condition up here in the Northeast!!! $500 is the deal. |
| Bookmarks |
