Old 02-20-2011, 09:35 AM   #1
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Crew Cab
ok i hhave a 79 k30 crew cab. i sold the dana 60. i have a suburban with good axels i want to use 1/2 ton runing gear so would u just cut the ton frame to make it a short bed and use a 1/2 ton back half or would use the burb front half and a 1/2 ton truck back half i can go either way the burb is rusty bad so i bought it for the running gear got good 350 t 400 tranny and 3:42 gears what will be the best way
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
Old 02-20-2011, 10:37 AM   #2
csa daddy
csa daddy's Avatar
Re: Crew Cab
either way will work but i imagine cutting the burb an a short bed truck an put it together
csa daddy is offline   Reply With Quote
Old 02-20-2011, 08:19 PM   #3
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Re: Crew Cab
thats what i think i think the burb frame be plenty big enough and loose the big frame less whight
1967 Chevy stepside
Old 02-21-2011, 09:27 AM   #4
ghettoluxury
ghettoluxury's Avatar
Re: Crew Cab
That is how Doug and I built the frame under his crew short dually and this is the abuse it gets put through.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 02-21-2011, 10:45 AM   #5
dropd80s
dropd80s's Avatar
Re: Crew Cab
I wouldn't do either, I would just shorten the one ton frame. That is the way i did mine and I can't imagine putting two different frames from different trucks together would be easier. Plus I think this way gives you the best looking and strongest end result. JMO.
dropd80s is offline   Reply With Quote
Old 02-21-2011, 06:46 PM   #6
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Re: Crew Cab
well then u have to put spring perch on the 1/2 ton axel to make it match the crew cab springs i want to run 1/2 ton axels not 3/4 ton or 1 tons
1967 Chevy stepside
Old 02-24-2011, 03:41 PM   #7
dropd80s
dropd80s's Avatar
Re: Crew Cab
or swap the hangers from the 1/2 ton frame. Again, not that hard to do. I figured if your up to the task of cutting and welding a frame, knocking out a few rivits or welding two spring perches wouldn't be something beyond your capabilities. Again, in my opinion its the better looking end result.
Old 02-24-2011, 04:11 PM   #8
Red1
Re: Crew Cab
I'm in the prosses of doing this right now. Unless you are using a 1 ton dually the spring mounts ar the same. If it is a dually they put spring mounts narrower
Red1 is offline   Reply With Quote
Old 02-24-2011, 04:58 PM   #9
dropd80s
dropd80s's Avatar
Re: Crew Cab
This is not true, all one ton frames either dual or single rear wheel have narrower perches. I have had a 79 and 84 crew cab single wheel K30, both had narrow perches.
Old 02-24-2011, 09:28 PM   #10
Red1
Re: Crew Cab
dropd80s is correct the 3/4 tons were wider. I had thought the donner truck I was using was 1 ton but in fact it is a 3/4 ton sorry for the confusion.
Old 02-25-2011, 09:32 AM   #11
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Re: Crew Cab
my crew cab is a dooly and i sold the dana 60 out of it and going to sell the duel wheel rear and i want all 1/2 ton rear out of my burb under it
1967 Chevy stepside
Old 02-26-2011, 04:44 AM   #12
Your41Plague12
Your41Plague12's Avatar
Re: Crew Cab
Ok, then you're going to need to move the spring perches on the axle to a narrower width between them, so it matches the distance between the leaf spring center pins on your one ton. If you're up to cutting up a frame and welding it, this should be a simple task.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 03-03-2011, 12:03 AM   #13
bigblock79
67 Chevy Stepside
bigblock79's Avatar
Re: Crew Cab
the way i see i got to cut a frame any way i go. So why not loose the lbs of a 8 inch frame and go with the burb fame cause i want a short box crew cab so i have to cut the one ton frame so why not loose all the lbs i can
1967 Chevy stepside
