02-25-2011, 03:45 AM | #1 |
Running Gear Swap Questions
Hey all!
Question 1: I have an '87 1/2 ton 4x4 that came with a 7 spring pack on the left side and a 5 spring pack on the right side. 3 springs in each are cracked/broken and I would like to replace them with a good set off of a parts 3/4 ton 4x4 truck I have. Is this doable without swapping hangers? Question 2: I have an '88 parts Suburban that has 3/4 ton 4x4 running gear with 4:11 gears that I would like to swap everything, except the rear springs, under the '87 truck. Will I/should I swap the front sway bar with it? And will the front springs swap to the '87 without swapping the hangers as well? Thanks for the help. |
02-25-2011, 04:14 AM | #2 |
Re: Running Gear Swap Questions
The fronts should swap out just fine. The rears mite be different lengths. Just measure from eye to eye on both sets to make sure. I don't think the sway bar would matter.
Professional hot glue and pop cycle stick engineer. 72 K/20 soon to be C/10, 454, Th400, 9” rear. 01 GMC 2500HD 8.1, Allison, daily/towpig gas guzzler. 78 Bahner 19’ jet boat, 460 Furd turd. |
