Old 03-02-2011, 08:23 PM   #1
gavinmosher
84 c10 power window problems
Hey guys as stated having some issues with my windows..... They won't go up or down! Replaced the circuit breaker and srill nothing. Is It likely that both switches would go out? Pls help lol
gavinmosher is offline   Reply With Quote
Old 03-02-2011, 08:29 PM   #2
rblcori7
rblcori7's Avatar
Re: 84 c10 power window problems
i am having some of the same issues, on my driver side switched i can roll both windows up and down but on the passenger side switch will only allow me to roll the window up not down any suggestions for me?
84 Short bed 350: Hooker headers, flow master 40 series, edelbrock Intake manifold, Holly street avenger carb, 4 inch skyjacker suspension lift, 33x12.5 Toyo Open Country Mud Terrains, 3.73 gears
2011 Silverado LTZ
rblcori7 is offline   Reply With Quote
Old 03-02-2011, 09:17 PM   #3
gavinmosher
Ya neither of my switches will move either window kinda ****ty especially since Itd warming up
Old 03-02-2011, 10:54 PM   #4
dropd80s
dropd80s's Avatar
More than likely you lost power to the driver side switch. If I remember correctly power for both windows enter the dvr. door. Your switch on the pass. side gets power from the pass. switch on the dvr. side door. So if you lose that main feed on the dvr. side both windows wont work. Pull the switch on the dvr. side and see if you have 12V at any of the pins. If not, trace your wire from your circuit breaker to the switch. Not likely both switches would go out at the same time, but anythings possible!
dropd80s is offline   Reply With Quote
Old 03-03-2011, 07:20 AM   #5
tucsonjwt
For power window problems, pull the switch away from the door panel, operate the switch while wiggling the wires on the connector behind the switch. Push/pull lightly on the wires where they enter the connector. If the switch works intermittently, then I suspect this connector/harness. The generic harness is still available from AC/Delco (PT254). In my experience, a lot of switches and motors were replaced when it was really the harness that was the problem.
tucsonjwt is offline   Reply With Quote
Old 03-03-2011, 11:14 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
i've found the wire breaks in that black tube in the door jam
there is a harness/plugin under the edge of the dash for the door
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-07-2011, 11:47 AM   #7
dropd80s
dropd80s's Avatar
Yeah, but it might be better to just take the fender off next time you are trying to access the jam
Old 03-07-2011, 06:23 PM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
what can i say......
Apparently excessive alcohol was used to find the proper location....
and the window motor still won't work,but now i know where it's broke lol
John
