Old 03-09-2011, 08:25 PM   #1
fleabrain
steering column question
Hi i'm new on here. I have a 66 c/10 daily driver (will be posting pics soon) and the three speed steering column is wearing out. I have access to a 63 column but i heard only 64-68 would work in a 66. Does anyone have any info on this?
fleabrain is offline   Reply With Quote
Old 03-09-2011, 08:27 PM   #2
DPowers
DPowers's Avatar
Re: steering column question
Don't know why it wouldn't
DPowers is offline   Reply With Quote
Old 03-09-2011, 08:30 PM   #3
lakeroadster
Why not rebuild your column? You can get new upper and lower bearings and a new turn signal switch.
lakeroadster is offline   Reply With Quote
Old 03-10-2011, 01:01 AM   #4
Captainfab
60-66 Nut
Welcome to the forum
The wiring plug on a '63 column is different than on the '64-'66's. Otherwise it will work.
Old 03-10-2011, 12:31 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Captn fab is very correct. If you are experiencing the shift lock up issue, then it may need more than just the upper and lower bearing.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-10-2011, 07:19 PM   #6
fleabrain
Thanks guys. Yeah i can't shift out of first gear when the truck is moving. I decided just to buy a floor shifter. Mr gasket has them fairly cheap
