03-14-2011, 02:00 PM | #1 |
Enjoying left field
rear u-bolt flip
Hey guys, quick question. I'm building a 70 K10, and I would like to flip the u-bolts in the rear so they go up like the front. Could I use top spring plates off the front? I have an extra set.
Posted via Mobile Device |
03-15-2011, 02:10 AM | #2 |
Enjoying left field
Re: rear u-bolt flip
Anybody?.........Bueller?........Bueller?.......
03-15-2011, 03:45 AM | #3 |
I don't know what kind of rear / front end you have, but I would have to say No unless the holes are slotted. The passenger side uses 2 different sized ubolts. The easiest thing to do is get out the trusty tape measure.
1968 K10/30 Frame Off Project "Overkill" My 5 year, $30,000.00 toy |
03-15-2011, 06:58 AM | #4 |
I thought the earlier 67-72 had nuts up. Later 73+ had the nuts facing down in the rear. Check out ruffstuffspecialities.com or diy4x4.com. It seems like i saw a kit to put the nuts uppward one of those places.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" |
03-15-2011, 07:54 AM | #5 |
The axle tube are different size from front to back so no you will need the correct spring plate for the rear.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
03-15-2011, 10:47 AM | #6 |
Enjoying left field
Ok, thanks for the answers.
03-15-2011, 11:54 AM | #7 |
What axle is in your truck? Do you have any pictures? I am only really familiar with 67-68 which point up. What year did they change from up to down, at the factory?
Here is the one that I was thinking of, by off road design. http://offroaddesign.com/catalog/uboltreversal.htm Here are several from ruff stuff specialties (I used the 14 bolt simple swap on my truck). You wouldnt neccessarly need to replace the spring perch. http://www.ruffstuffspecialties.com/...123bc9e924ecbe
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" Last edited by eric67m; 03-15-2011 at 12:00 PM. |
03-15-2011, 02:48 PM | #8 |
Enjoying left field
My parts truck is a 70 1/2T. It has a 12 bolt rear and a dana 44 in the front. The. Front is nuts up, and the back is nuts down.
