How strong is the Rockwell T-221
Just like the title says. The reason I ask is I am planning a swap and need to know if it will handle a 300-400hp 750-900ftlbs Cummins.
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12 67 C-20,292,SM420,HO72 90 Dodge W250 Cummins,NV4500HD,205,D60/D80 93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70 |
Re: How strong is the Rockwell T-221
I don't know about behind a Cummins but my father used his 65 K10 to haul 2.5 tons of water in the mountains of CO every other week or so. Rain, snow or shine....
![]() However if you already have everything yanked out, it might be a good time to get something a little newer and easier to get parts for.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call Last edited by Prerunner1982; 03-18-2011 at 02:25 PM. |
There is a good chance that wherever that Cummins is coming from there is a 205 close by. Why not fab in a 205 now while you are in the mood? And what I mean by in the mood is while you are in fab mode. The T 221 would probably take it for a bit. But when you need parts for it, and you will need parts because your case is probably " experienced " they will be harder to find than parts for a 205. Besides, how many destroyed 205's have you seen? I have seen two, both examples where extemely abused in all ways possible.
Custom Vehicle, Custom Problems. Last edited by LANDC; 03-18-2011 at 02:33 PM. |
![]() Join Date: May 2007
R U planing on doing 4 wheel drive burn out on pavement ?
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
No plans for 4wd burnouts. My plans for the truck would just be for driving and the occasional sled pull. But I am addicted to power so it won't be stock.
LANDC, The motor and NV I have were from a 2wd so I don't have a spare 205 and If i wer to use a 205 I'd like to use a divorced unit, However I do know where there is a 201 from an 63 PowerWagon.
The sled might be its down fall with that much torque.
