Old 03-18-2011, 03:54 PM   #1
woodwright
Enjoying left field
woodwright's Avatar
ford pitman arm
Ivve searched thrue here and pirates, and can't find what year and model fords have the correct pitman arm for crossover steering on my k10. I need to know what to look for at the pick yard. Thanks.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 03-18-2011, 08:33 PM   #2
b454rat
Re: ford pitman arm
78 and 79 1/2t, maybe earlier not sure. But these aren't a true bolt on for crossover. The taper doesn't match the GM DLE. Check out Parts Mike or Sky, any of those will have the right arm.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 03-18-2011, 11:24 PM   #3
woodwright
Enjoying left field
woodwright's Avatar
Re: ford pitman arm
Yeah, I know they're available everywhere. But I don't want to spend $80 when I can spend $20.
Clint
Old 03-20-2011, 02:31 AM   #4
woodwright
Enjoying left field
woodwright's Avatar
Re: ford pitman arm
So why couldnt you just use the ford TRE on one end of the draglink, and a chevy one on the other? I read somewhere that somebody had used one from a ford van. I'm thinking there has to be a bigger range of vehicles with pitman arms that work.
Clint
Old 03-20-2011, 05:48 PM   #5
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: ford pitman arm
78-79 Ford F-150 76-79 Bronco and 74-90 fullsize Jeep cherokee and Wagoneer.
And heres an article where a guy used one from a Jeep YJ
http://coloradok5.com/crossoversteering.shtml
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 03-22-2011, 09:10 AM   #6
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: ford pitman arm
I used the Ford pitman arm and bought the reamer to enlarge the taper. That way I could run the 1 ton TRE. I also had to heat and bend the arm a little to keep it from rubbing the frame. I had several people saying "Dont heat the pitman arm." Whell...that was about 3 years ago, and its still on there and still working perfectly.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
