Old 03-30-2011, 11:26 AM   #1
292farmer
292farmer's Avatar
what to clean frame with? and body mount ?
i took my bed off yesterday, god is it heavy! and i need a environmentally safe way to clean it as my and my neighbors well are within 30ft of the truck. i was gonna try pressure washing most the frame, but what else can i use?
also im pretty sure my body mounts are junk, im wondering how much the cab has sunk? the reason im asking is i've been wanting to lift truck roughly 2inches and im wondering how much i can gain with new mounts, im hoping an 1in my cab is 1/2in from frame in the back, im wondering how someones with new stock mounts measures? thanks everyone!
1972 gmc c25 292/sm465 dana 60 w/5.13s
1973 vw super beetle 1600cc/4spd(baja bug)
1974 chevy c60 351v6/np-540+2 speed eaton rear
2005 chevy cobalt 2.2l
292farmer is offline   Reply With Quote
Old 03-30-2011, 12:04 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: what to clean frame with? and body mount ?
Simple Green works really well. I've also had great luck with some stuff called B-52, but it will take paint off if you don't dilute it enough. You'll have to show us some after pics when you get it all cleaned up.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 03-30-2011, 12:08 PM   #3
292farmer
292farmer's Avatar
is b-52 good for the ground/ water? i plan on painting the suspension, diff gunmetal gray with red shocks and diff cover, and the frame im gonna rubber coat or maybe rhino line..think it will look good at least in my head..thanks for the reply!
Old 03-30-2011, 12:16 PM   #4
dave2953
dave2953's Avatar
Just re-read your post and noticed the environmentally safe part. Not sure either of these lend themselves to being environmentally friendly, although I think Simple Green is more so than the B-52. You could go at it with a wire wheel on a grinder, but it would be a ton of work and ridiculously messy. Maybe you could hit it with a pressure washer and soap see if that breaks up the big stuff.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 03-30-2011, 12:28 PM   #5
project67-stepside
project67-stepside's Avatar
get the driveway degreaser from home depot, wear gloves when messing with it, and a presuure washer. done....
it usual better and faster if u figure it out yourself!!!!
project67-stepside is offline   Reply With Quote
Old 03-30-2011, 12:34 PM   #6
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Yep, the body mounts are shot!! I would go after the chassis with a scraper and get off as mutch as I could that way first. That way you capture the undercoating and majority of oil soaked dirt. Then I would go after it with a product called "Oil Eater". Cosco sells it by the gallon. Spray it on undilluted and let it set for a while, then take a "Oil Eater" soaked scrub brush to scrub the chassis down. Pressure wash it all off and repeat as necessary. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 03-30-2011, 12:53 PM   #7
JORGIE95961
I CLEANED UP MY FRAME WITH A SCRAPER AND A WIRE BRUSH FIRST IT WAS THICK!! .. I had th etruck in the garage and it was raining so i then used my shopvac and pickd it all up.. the next day i used PURPLE POWER from good ole Wallmart and a pressure washer.. no matter wht your gonna end up with greas and gunk in the ground
JORGIE95961 is offline   Reply With Quote
Old 03-30-2011, 02:47 PM   #8
leddzepp
Moderator
leddzepp's Avatar
POR marine clean works fantastic at removing 40 yrs of caked on junk. simple green works great for maintainance and general clean up. both are biodegradable.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 03-30-2011, 03:54 PM   #9
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
^^^^^ AGREED!
Marine Clean from POR15 is great. Plus it says it's biodegradeable. I used it to degrease the frame and crossmember in the front of my '72 GMC. Also used it on the firewall. Best part is... it won't eat the paint.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 03-30-2011, 04:16 PM   #10
292farmer
292farmer's Avatar
thank you everyone right now im scraping it off, think i'll try pressure wash with simple green tomm as i have simple green.
Old 03-30-2011, 05:37 PM   #11
292farmer
292farmer's Avatar
well i went and scraped then coated with simple green scrubbed with steel wool then rinsed with the garden hose looks 10x better i say!
Old 03-30-2011, 05:44 PM   #12
leddzepp
Moderator
leddzepp's Avatar
lookin tough!
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-30-2011, 06:18 PM   #13
tim21391
tim21391's Avatar
i used wire wheel. da sander. hand sanding. scuff pad. wax and grease remover. rust convertor primer. and a few cans of undercoating.. can of high temp paint for my exhaust.. and 2.5 years later she still looks new... check out my build thread for pics
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
