Old 04-04-2011, 09:33 PM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
Big Red Air Valve Questions
I have split my big red valve into two parts. So now I have two set of two valves. I have put the set on each side of the frame.
I wanted to connect the valves with a supply line going from "suppy" of one to the "suppy" of the other. I also wanted to run a suppy line from one tank to the other tank.
Will this cause any problems?
Another question, There is an exhaust port on the valve system. What do i need to connect to this? Nothing is shown on the instructions.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 04-05-2011, 02:38 PM   #2
tech@scottshotrods
Re: Big Red Air Valve Questions
you will have no issues setting it up that way at all, the valves and tanks will be pressurized at the same PSI, as for the exaust port just leave them open.
tech@scottshotrods is offline   Reply With Quote
Old 04-05-2011, 03:21 PM   #3
jugernot
Life, Be In It.....
jugernot's Avatar
Cheers.................Thanks
Old 04-05-2011, 07:10 PM   #4
tech@scottshotrods
anytime!!!!
