s10 swap...rim/tire configuration???
I would like to know if this configuration would work on an s10 frame swap. I have the stock rear end, not the 4x4. I don;t have a problem with tubbing, I just want to make sure that there is clearance and that it would look decent. Maybe someone has this setup and could post a pic of how it looks. The truck is at stock height, no lowering blocks or anything.
Front: rim: 18x8 5x127 Offset 0 tire: 245/40/18 Rear: 20x8.5 5x127 Offset 7 tire: 275/35/20 thanks for any help. |
Re: s10 swap...rim/tire configuration???
Im not sure if 0 offset is centered and what that 7 offset is. But 18x8 and 20x8 should look pretty good provided you have the right offset. Here is a couple of pictures of mine with 20x8.5 with 6.25bs and 20x10 with 4.75bs.
is that stock ride height on the truck...not lowered? If so, that looks pretty sick!
what are the tire sizes? Last edited by vintage_car; 04-18-2011 at 04:03 PM. |
#4 | |
what rear end are you running?
#6 | |
![]() Join Date: Mar 2007
What brand are your tires? I have been having trouble finding a matching set in those exact sizes that arn't ridiculously priced. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
that is wider than the stock s10 rear. can't remember buy how much but i will have to take that into consideration on backspacing...
![]() Join Date: Jul 2007
At close to stock height I don't think you will have any real problems. Most of the guys have to run spacers on the front to get a more standard size tire out to where it looks right and doesn't set in too far.
The info I found says that the 2wd S-10 rear axle is 53-5/8 wheel mounting surface to wheel mounting surface while the 4x4 axle is 60 inches mounting surface to mounting surface. I've never measured what my tires are outside to outside but I have about a half inch clearance between the fender lip and the sidewall. I have 255-60x15 on 8 inch rims on it now with a mid 70's Nova axle. With the axle width and the wheel/tire info you should be able to figure the total outside width or what it would be fairly easily by laying a straight edge across the sidewall and measuring from the wheel's mounting surface to the straightedge multiplying that x 2 and adding in the axle width. |
#10 | |
these numbers make my head hurt...
Marc, are you going to be changing youre wheels in the future? If not the size tires i have may not work for you.
#13 |
If you can tell me what back spacing you are going with i will help you all that i can with the set up
#14 |
not lowering the truck...won't be able to get it out of my crazy driveway. as for backspacing, I don't have a clue. I just found out backspacing is different from offset. haha
#15 | |
#16 |
thought about airbags...but $$$ is tight.
thanks for the backspace instructions, dumb question... so I assume I can measure the current backspace of my 15" rims and then add the difference from the edge of the fender to the front of the rim to figure out what I would need for the new rims/spacers for the look I want? |
#17 |
Is it an early bronco 9" or has it been narrowed?
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#18 | |
Thanks Marc
#19 | |
#20 |
I bought mine from Discount tire, Dunlop signature series I went with a 255/35/20 on the 20X10 and 225/40/18 on the 18x8. They were really good on price and they had a rebate to boot.
#21 |
with a stock s10 rear will I need spacers, or is there a way to figure that into the backspacing of the rim?
#22 |
You can figure that in, it all depends on the wheels you want. I could have gotten American Racing Torq-Thrust and had many different choices on backspacing, but the price was CRAZY!!!!! So I decided to get the Boss 338's instead for half the cost.
On back I began w/ the original 2wd s10 rearend but had to run 2 inch spacers. The gear ratio was not what I wanted so I went and bought a 4x4 rearend w/ a better ratio. The 20x10's are 20mm offset w/ a backspace of 6.225. Up front 18x8's are +2mm offset w/ a 4.517 backspace. I am running 2 inch spacers on the front. Here's a picture of the truck in which I feel in love with the wheels notice the deep offset. I think it's on a S10 chassis too. |
#23 |
thanks for the info and pic. That is a GREAT look! I have 15" weld rims and really want to upgrade. Might have to put those up for sale and bite the bullet on rims. I had read the Boss 338's had some finish issues? Are you experiencing any of that? Where did you get those 2" spacers?
#24 |
I haven't even washed mine for the first time yet since truck ain't running. So I don't know about issues but, they are definately a popular wheel. I bought my spacers from Ecklers Corvette in 2002 to run 17 X 9.5 vette wheels on my s10 I had at that time. I think they have since discontinued them. They haven't been ran in over 6 years. They actually are sold thought Vette Brakes in St Petersburg, Florida.... I think.
#25 |
1952ssr- sent you a pm
