Old 04-18-2011, 04:39 PM   #1
61apachespeed
carb whistling
so my carb started to whistling when i went to adjust it. anyone have this before ???
61apachespeed is offline   Reply With Quote
Old 04-18-2011, 05:13 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: carb whistling
Make sure all your vacuum lines are connected. Sounds like a vac leak somewhere.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 04-18-2011, 05:18 PM   #3
oem4me
Re: carb whistling
Maybe it was just happy to be getting some attention. What did you adjust to make it whistle? and yep, check the vac lines.
Old 04-18-2011, 06:24 PM   #4
70inline6
Re: carb whistling
Base plate gasket (carb to manifold). If it's one of those thin paperboard ones I'd look there. Use a thicker cardboard gasket and some (thin layer) RTV.
70inline6 is offline   Reply With Quote
Old 04-18-2011, 06:45 PM   #5
61apachespeed
Re: carb whistling
who makes the thicker cardboard gasket i can only find the thin ones.
Old 04-18-2011, 07:02 PM   #6
70inline6
Re: carb whistling
Most carb kits come with the thicker ones. You may get by with some RTV on your finger, smeared around the base.... if you're not too fussy about those things. Spray some carb cleaner or open a propane bottle (slowly) near the gasket around the base... if the RPM goes up, you have a leak. Smear some RTV there.
Old 04-18-2011, 09:48 PM   #7
jbgroby
jbgroby's Avatar
Re: carb whistling
While it works?
jbgroby is offline   Reply With Quote
Old 04-20-2011, 03:46 PM   #8
62 Longbed
62 Longbed's Avatar
Re: carb whistling
I agree with others , carb spray or a little propane really works ... Ck. vacumn lines , ( infact as you pull each vacumn line off .. take a razor and recut and fit back on , that way the hose isn't swallon at the end and you have a clean cut and fit ) .. carb base , carb bolts tight on manifold , tighten all screws both on top and underneath carb if pulled , ck. throttle shaft bushings ... just covering the bases .. Good Luck ...
62 Longbed is offline   Reply With Quote
