Throttle cable....
I got a 85 Chev Shortbox with a ZZ4 350cid, What kind of cable do you use?, mine just make a loop and make the accelerator pedal hard as a rock...
GM Addicted
Re: Throttle cable....
Ill be the first to tell you. Buy your self a lokar cable and be good. I just installed one in my truck and makes the pedal feel way better. Nice and simple upgrade took like 30 minutes to do, the first one ive ever done too.
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
I looked and looked for a shorter one myself until the parts guy got sick of me, but nothing
#4 | |
http://www.summitracing.com/parts/LOK-TC-1000U/ |
Thanks all for the tips , I will go with Lokar
Just wanted to add to this, that while the lokar i am sure works great, there is a good chance your current cable is just done for. And even if you go for the lokar, I figured it won't hurt to have my advice for anyone searching in the future.
I just went thru this on my suburban, and while a tbi is different from a carb, a throttle cable is a throttle cable. Mine is currently and was before looped around too. I took the cable off the throttle body and it seemed to move just fine, and I had check the throttle body itself and the pedal, and both seem good as well. So I figured, what the hell, and spent the money on a new one and voila... pedal feels just like my Blazer with the tbi does. In other words exactly like it should be and not hard.
1995 Suburban K2500 454.....off road & towing 1999 Astro, work van 2006 Silverado 2wd 5.3 w/4.5" lift and 33s Last edited by TheApocalyptican; 05-27-2011 at 02:21 AM. |
