Old 05-24-2011, 11:27 PM   #1
dandansuperman
dandansuperman's Avatar
Chevy Orange Engine Paint Question????
I am painting my engine with Plastikote Chevy Orange engine enamel. I have spent hours sanding and cleaning the engine so I am ready to paint. I started putting on the first couple of coats and it seems really thin. The paint shop owner told me not to prime the engine because the paint will hold up better without it. I figured I would let it dry for a few days and then apply some more coats. Everyone I have talked to said orange paint is just really transparent. Should I go and buy primer to put on first, or should I let it dry and put some more coats of the enamel on? Please give me some advice.
dandansuperman is offline   Reply With Quote
Old 05-25-2011, 05:47 AM   #2
JimKshortstep4x4
Re: Chevy Orange Engine Paint Question????
I have always just sprayed the engine paint on, no primer. The paint is thin and you have to be carefull not to get runs.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-25-2011, 06:14 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
no primer.
No reason to wait a couple days either. Wait till the paint is tacky, then give it another light coat. If you let it dry all the way, then you'll need to give it a light sanding to spray over it.
Old 05-25-2011, 06:29 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
VHT is better. It's not watery like Plasikote.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 05-25-2011, 05:47 PM   #5
RW71
RW71's Avatar
Here's my 283 with 3 coats of Plasikote with no primer.
RW71 is offline   Reply With Quote
Old 05-25-2011, 08:06 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Plastikote here too... at least 3 coats. Sometimes more. Never used a primer.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-25-2011, 10:06 PM   #7
VentureRick
VentureRick's Avatar
Here's my 427 with 2 coats of POR15 engine paint, everything but the valve covers.
Rick
69 SWB Project
95 Suburban Daily Driver
47 Flxible Motor Home 427 GMC 4spd Allison
71 C-10 LWB 307/350 (parted out)
64 SWB Custom Cab 283 powerglide (sold)
2000 Yamaha Venture
VentureRick is offline   Reply With Quote
Old 05-25-2011, 10:56 PM   #8
72lb4x4
What's the application for the 427?? Cool looking, but that pump may not fit under the hood...
Maybe in the also cool looking motorhome/bus in the background?
72lb4x4 is offline   Reply With Quote
Old 05-25-2011, 11:49 PM   #9
leddzepp
Moderator
leddzepp's Avatar
POR is the only way to go. I have used it on engines for years, still looks brand new.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-26-2011, 12:22 AM   #10
dandansuperman
Back to square one. The paint shop said I bought a bad batch of paint. I stripped all the paint off with aircraft stripper and a pressure washer. I am down to the bare block now. I ordered the POR 15 kit. I will never use Plastikote again even if I did get a bad batch. It was like spraying on an orange tinted clear coat. I will keep you updated on my progress. I could use some POR 15 tips.
Old 05-26-2011, 12:50 AM   #11
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Here's the number one POR-15 tip in my experience: wear rubber gloves, that stuff will be on your skin or whatever forever.
Zoomin is offline   Reply With Quote
Old 05-26-2011, 02:56 AM   #12
leddzepp
Moderator
leddzepp's Avatar
I agree. Just follow the instructions that come with the kit, make sure that engine is CLEAN. The marine clean that comes in the kit is like simple green x 100, it works very well. Wear gloves and a respirator mask, even if you brush it on. You will be very happy with the results.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-26-2011, 03:02 AM   #13
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
i concur
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 05-26-2011, 03:05 AM   #14
fastwillie 696969
~Rest In Peace~
70 gmc 355 supercharged
Old 05-26-2011, 11:06 AM   #15
VentureRick
72lb4x4, it's going in a 46 Flxible Clipper, the blue one in the background is a 47 and has a 427 with a 4 spd allison automatic in it already.
Rick
69 SWB Project
2000 Yamaha Venture
Old 05-26-2011, 11:36 AM   #16
MARKDTN
I have never used primer with engine paint.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-26-2011, 04:00 PM   #17
Autoblueprint
Autoblueprint's Avatar
Thumbs up Re: Chevy Orange Engine Paint Question????
Yep. X2.
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
Old 06-13-2011, 06:58 PM   #18
dandansuperman
I finally finished my engine. It turned out great. POR 15 is a little hard to apply, but overall its a great finish.
Old 06-13-2011, 07:20 PM   #19
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
WOW!
Give us some details on that engine.
Looks very good.
Paint turned out great huh?
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 06-13-2011, 09:04 PM   #20
hayhauler71
hayhauler71's Avatar
2 coats ppg epoxy primer on a hot tanked block and vht engine enamel and still looks like new 5 years later
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 06-14-2011, 11:03 AM   #21
dandansuperman
Engine Block Casting Number: 3970010 (1968-1979) 4 Bolt Main
The engine was carefully engineered to be a street-able 375-400 hp
The engine was blueprinted and balanced with 9.5:1 compression.
The heads were opened up to 2.02 intakes
1.86 exhaust with hard seats installed so that pump fuel can be run.
Heads were ported and smoothed.
The engine had a high lift cam installed (5/8 race cam)
1:1.5 roller rocker arms installed.
The timing chain is a double roller.
The oil and fuel pump is a stock Z-28 spec unit.
Intake is a Holley 750 double pumper vacuum secondary’s.
Edlebrock 600 cfm carb
Edlebrock performer manifold
Accel GM HEI Distributor
PROFORM ORANGE SLANT EDGE VALVE COVERS
TAYLOR SPIRO-PRO IGNITION WIRES HOT ORANGE
EDLEBROCK PRO-FLO AIR CLEANER CHROME LOGO
FRAM AIR HOG AIR FILTER
SANDERSON-CC10 HEADERS
CHROME PULLEY’S
CHROME OIL PAN
BILLET DIP STICKS
MADE FOR YOU PRODUCTS VERTICAL WIRE LOOM KIT
700R4 TRANSMISSION W/ COAN 3500 STALL
TCI 700R4 TV CABLE CORRECTOR KIT AND BRACKET
KUGEL KOMPONENTS SHIFT LINKAGE
EARLY CLASSIC ENTERPRISES TRANSMISSION CROSSMEMBER
