05-29-2011, 05:12 PM | #1 |
~Rest In Peace~
how can you tell if a truck is long or short bed
how can i tell by looking at a frame if its long or short bed ? any help be nice
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
05-29-2011, 05:58 PM | #2 |
Re: how can you tell if a truck is long or short bed
FastWillie......
The easiest way....at a glance The short bed frame is 192" over-all The long bed is 212" Give or take an inch
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
05-29-2011, 06:02 PM | #3 |
If you don't have a tape measure, look for the bed support mounts between the cab and the rear axle;
LWB two sets, SWB one set.
'69 Fleet It ain't yours, if you didn't build it! |
05-29-2011, 07:28 PM | #4 |
Active Member
Sometimes it's hard to tell if looking at a pic but if you have a view of the bed, a long wheel base has three holes for bed rails on each side -front, middle, back. The short bed has two -front and back.
05-29-2011, 07:36 PM | #5 |
The Niner
If you had one of each out in a field the shortbed one would be the one everybody would be drooling over while the longbed one would have a small cult following by people like myself.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
05-29-2011, 08:30 PM | #6 |
05-29-2011, 09:50 PM | #7 |
~Rest In Peace~
thanks for the info
05-29-2011, 10:08 PM | #8 |
Cruzin
as said right behind the cab, the mounts here pics
top long bed bottom short bed
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
