Old 06-20-2011, 04:51 PM   #1
awc7772000
awc7772000's Avatar
Help me guys please!
ok just rebuilt my motor for the second time because it kept blowing headgaskets and now its running hot... just changed the radiator the fan clutch the thermostat and the water pumps also new wtf could be happening guys?
awc7772000 is offline   Reply With Quote
Old 06-20-2011, 04:58 PM   #2
Phil750
Re: Help me guys please!
Is it possible the tstat is in upside down.
Phil750 is offline   Reply With Quote
Old 06-20-2011, 04:58 PM   #3
awc7772000
awc7772000's Avatar
nope :/ i dont understand it
Old 06-20-2011, 05:11 PM   #4
Doug_J
Doug_J's Avatar
try taking the tstat out and I would think this would be it but maybe got air in the coolent. And if you just had it rebuilt an it wasnt doing this before maybe some how your block got junk in it during the rebuild an its plugged up now.
Doug_J is offline   Reply With Quote
Old 06-20-2011, 05:49 PM   #5
rwhit57
rwhit57's Avatar
Just curious did you have the heads and block magnafluxed?
rwhit57 is offline   Reply With Quote
Old 06-20-2011, 07:28 PM   #6
Goldfinger
Goldfinger's Avatar
make sure you have proper oil pressure. insufficient lubrication can cause it to heat faster than the cooling system can over come. is you radiator hooked up properly. do you have proper flow when the thermostat opens. have you used any sort of leak seal as the can build up and clog up the radiator
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 06-20-2011, 09:56 PM   #7
rayfinseats
Was your block and heads planed? If they arent flat it will continue to blow head gaskets.
rayfinseats is offline   Reply With Quote
