Old 06-21-2011, 09:16 PM   #1
FMBL
FMBL's Avatar
Adding Rear A/C
How hard and what would be involved with adding rear A/C to a 2 dr Tahoe? Just wondering cuz the truck A/C has a hard time cooling the whole entire cab. I was thinking about trying to get most of the parts from a 4dr Tahoe or Suburban.
78 El camino
89 GMC SWB
98 Z28
99 2dr 2wd Tahoe (sold 8/31/2012)
07 Yukon SLT
09 G8 GT
FMBL is offline   Reply With Quote
Old 06-22-2011, 07:21 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Adding Rear A/C
Nothing is too hard for someone else to do....
If you know what parts you need for the rear air, it seems to me that the hardest part would be the connections to get the refrigerant to the unit.
Member Nr. 2770
Old 06-26-2011, 12:45 AM   #3
mountie
mountie's Avatar
Re: Adding Rear A/C
Probably 'hard & involved'..... unless you have a fat wallet....
I used an insulated 2 1/2" flex hose, a square-to-round downspout part, and attached it to my passenger floor vent ( closing the driver's side vent). Ran it under the seat and up the back.
It cooled (or heated) the entire back of my covered bed. It worked!
It cost very little.
mountie is offline   Reply With Quote
Old 07-19-2011, 10:15 PM   #4
chris@bigjranch.com
KIDHLR
chris@bigjranch.com's Avatar
Re: Adding Rear A/C
I suppose if you had all the parts it would just be a mater of finding space to put the big thing. I am curently trying to build my own extended cab and looking into moving the rear a/c from the sububan to the new truck cab. Very interested in what you come up with.
Christopher Johnson
Project - Grafted In AKA the "KIDHLR"
Conversion - KIDHLR Meets LPG
KIDHLR 2.0 Rise of the diesel(a 6.5 powered 6 Door pickup)
Romans 11:17-22
"Branches were broken off so that I could be grafted in"
chris@bigjranch.com is offline   Reply With Quote
Old 07-19-2011, 11:19 PM   #5
mountie
mountie's Avatar
Re: Adding Rear A/C
Seems to me, in Hot Rod / fabrication mags have "add-on" heaters & A/C units for vehicles that don't have 'em. Try that?
Old 07-20-2011, 05:44 PM   #6
chris@bigjranch.com
KIDHLR
Re: Adding Rear A/C
found it. "Old air products" sells some add on kits for a little over $500.
Christopher Johnson
Romans 11:17-22
Old 07-20-2011, 05:46 PM   #7
chris@bigjranch.com
KIDHLR
Re: Adding Rear A/C
Here's the link http://www.oldairproducts.com/catalo...em-p-4460.html
Christopher Johnson
Romans 11:17-22
Old 07-20-2011, 06:54 PM   #8
bighaas79
Re: Adding Rear A/C
Personally i fail to see the point. If your ac system is in good working order cooling should not be an issue. Not to mention the fact that the rear ac is run off the same compressor, so adding onto an already under performing system would just make it that much worse. My recommendation would be to spend that money and time on going thru the whole sytem, and getting the original system up to snuff. Things like cleaning out the fins in the evaporator and condensor, flushing the system, new orrifice tube, and the correct ammount of oil and refrigerant can do wonders, without all the extra work of fabbin up or retrofitting a system that u don't really need.
bighaas79 is offline   Reply With Quote
Old 07-21-2011, 08:23 AM   #9
FMBL
FMBL's Avatar
Re: Adding Rear A/C
My thinking is that I have a standard cab truck A/C in a 2dr Tahoe. The front seat cools great. But the kids in the back seat are cooking because there is no air flow. If the front vents work so great why would they have rear A/C on the 4dr Tahoes and Suburbans?
78 El camino
89 GMC SWB
98 Z28
07 Yukon SLT
09 G8 GT
Old 07-21-2011, 08:32 AM   #10
FMBL
FMBL's Avatar
Re: Adding Rear A/C
I will have to look into this. Thanks
78 El camino
89 GMC SWB
98 Z28
07 Yukon SLT
09 G8 GT
