06-24-2011, 10:38 PM | #1 |
Just Not Low Enough!
GEN III 5.3L Question
alrighty, got a good one for you all,
ok so looking at doing the gen 3 swap, have an 01 motor and ecm, need the harness. have a guy here in town with an 07 (i believe) harness and pcm. will this work on my 2001 motor? i know the pcm pinouts are different, but i dont know if all the connectors are the same.. thanks in advance. oh and any advice on the gen 3 swap would be awesome, i have alot of it scienced out but i am alweays ope to suggestions... thanks!
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
06-24-2011, 11:19 PM | #2 |
Has more rust than truck...
Re: GEN III 5.3L Question
Can it be done yes, but if you have a 01 motor with the cable type throttle body, the easiest is to get a 99-02 harness and computer. After 02 there are quite a few changes in connectors and they went to drive by wire(DBW). In my sig there is a link to the LSx FAQ, lots of good reading.
06-24-2011, 11:30 PM | #3 |
well i wouldnt be considering it but the guy is selling me alot of parts for a cheap price and its very tempting. i know dbw can be converted dbc, so thats not the issue, i am more concerned with the connectors and such like you stated...
06-24-2011, 11:38 PM | #4 |
I'd say go for it, to me dbw would be easier than mods for a cable. and swap throttles and sensors
71 f250 cs 390ci t18 33s "under construction" 69 custom/10 307 a/c 8 track will be tbi had 2 E36 325i's Last edited by 1mouse3; 06-24-2011 at 11:39 PM. |
06-24-2011, 11:46 PM | #5 |
Off the top of my head, O2s, Alternator, MAF connectors and then the TPS/IAC vs. DBW with the TAC. Also being it is a 07 it may use separate engine and trans computers with the 58x reluctor wheel on the crank. Even if you get it cheap, I would sell/trade it for a older harness.
06-25-2011, 03:38 AM | #6 | |
Posted via Mobile Device |
06-25-2011, 07:43 AM | #7 |
Yeah, its just not worth the hassle.
06-25-2011, 08:09 AM | #8 |
Yep don't do it, like they said the comp will not work with a cable TB, Cable throttle body's have iac valves to control idle, that newer computer does not have the hardware to control an iac valve
68 SWB Fleet 383 |
06-25-2011, 10:10 AM | #9 | |
thanks for all the input!!
